How to troubleshoot the Gateway connection to EcoStruxure IT
Troubleshooting
How to troubleshoot and solve issues configuring the EcoStruxure IT Gateway
  • EcoStruxure IT Help Center
  • Gateway
  • Troubleshooting
  • How to troubleshoot the Gateway connection to EcoStruxure IT
  • Mark as Read
  • How to troubleshoot the Gateway connection to EcoS...
  • How to troubleshoot SNMP communication issues in t...
  • How to solve the cloud connectivity untrusted SSL ...
  • How to set up the Gateway proxy settings
  • How to restart the Gateway Service
  • How to replace the self-signed SSL certificate in ...
  • How to replace a device in EcoStruxure IT Gateway
  • How to disconnect or reconnect a Gateway from EcoS...
  • How to create a device walk file for EcoStruxure I...
  • How to allow a targeted read for Device Support
  • Gathering Gateway logs for troubleshooting
  • Gateway restore fails on some non-English locales
  • Gateway appliance network problems due to bad imag...
  • Gateway Device Communication Alert
  • Galaxy UPS is offline after updating the Gateway
  • Device serial numbers and unique identifiers
  • Device is offline after replacement or RMA
  • Device discover fails - SNMP is disabled by defaul...
  • Cannot discover Redfish devices in Gateway
  • Cannot discover NetBotz devices in Gateway
  • Web server port 443 is being used by another appli...
  • Troubleshooting issues connecting your Gateway to ...
  • Troubleshooting Gateway device discovery failure
  • SNMP walks, Modbus polls, and Redfish discoveries
  • NetBotz devices appear in the list of unknown devi...
  • NetBotz 4.x discovery issue when Gateway proxy set...
  • My device name didn't update in the Gateway after ...
  • My device is not responding - Gateway 1.4.0
EcoStruxure IT Support
Request Support
Back to Troubleshooting
  • Mark as Read
Picard EcoStruxureIT
‎2022-03-10 02:37 AM
Last Updated: Sisko JLehr Sisko ‎2025-06-06 06:42 AM
Network or proxy configuration changes can disrupt connectivity to EcoStruxure IT.
To restore the Gateway's connection to EcoStruxure IT, verify that:
  • The computer the Gateway is installed on is available.
  • The Gateway is installed on a computer that is always on, and it is connected to the internet.
  • You can log into the EcoStruxure IT Gateway.
Once you have verified the Gateway is connected to the internet:
  1. Restart the Gateway Service. See how
    Check the EcoStruxure IT mobile app to verify the connection to EcoStruxure IT.
  2. Restart the computer running the Gateway if possible.
  3. Navigate to well-known domain names to verify DNS is working.
  4. Check your network settings with your IT team.
    If the Gateway still cannot connect to EcoStruxure IT, contact your IT team to verify they have not made network infrastructure changes that block outbound traffic.
    Ask them to check the configuration of the computer running the Gateway against the System requirements for EcoStruxure IT Gateway.
100% helpful (1/1)
