How to allow a targeted read for Device Support
Troubleshooting
How to troubleshoot and solve issues configuring the EcoStruxure IT Gateway
  • EcoStruxure IT Help Center
  • Gateway
  • Troubleshooting
  • How to allow a targeted read for Device Support
  • Mark as Read
  • How to troubleshoot the Gateway connection to EcoS...
  • How to troubleshoot SNMP communication issues in t...
  • How to solve the cloud connectivity untrusted SSL ...
  • How to set up the Gateway proxy settings
  • How to restart the Gateway Service
  • How to replace the self-signed SSL certificate in ...
  • How to replace a device in EcoStruxure IT Gateway
  • How to disconnect or reconnect a Gateway from EcoS...
  • How to create a device walk file for EcoStruxure I...
  • Gathering Gateway logs for troubleshooting
  • Gateway restore fails on some non-English locales
  • Gateway appliance network problems due to bad imag...
  • Gateway Device Communication Alert
  • Galaxy UPS is offline after updating the Gateway
  • Device serial numbers and unique identifiers
  • Device is offline after replacement or RMA
  • Device discover fails - SNMP is disabled by defaul...
  • Cannot discover Redfish devices in Gateway
  • Cannot discover NetBotz devices in Gateway
  • Web server port 443 is being used by another appli...
  • Troubleshooting issues connecting your Gateway to ...
  • Troubleshooting Gateway device discovery failure
  • SNMP walks, Modbus polls, and Redfish discoveries
  • NetBotz devices appear in the list of unknown devi...
  • NetBotz 4.x discovery issue when Gateway proxy set...
  • My device name didn't update in the Gateway after ...
  • My device is not responding - Gateway 1.4.0
EcoStruxure IT Support
Request Support
Back to Troubleshooting
  • Mark as Read
Picard EcoStruxureIT
‎2018-11-14 01:32 PM
Last Updated: Sisko JLehr Sisko ‎2023-12-19 06:26 AM
If you have created a device support ticket and have been asked to enable targeted reads for a device, you set the permission to do so in the Gateway server's web user interface in the Settings > Advanced > Targeted reads option.
To create a Device Support ticket to allow EcoStruxure IT Gateway to discover an unsupported device:
  1. If unsupported devices are listed on the Device discovery page in the Gateway user interface, click View details.
  2. Click Need device support? Submit a DDF Request to request support for a device you are unable to discover.
To set the permission to perform a targeted read, check the appropriate box based on how you are trying to discover the device:
  1. In the Gateway user interface, go to Settings > Advanced > Targeted reads.
  2. If you are trying to discover a serial Modbus device, check the first box, Allow Schneider Electric to perform targeted reads on devices serially connected to your EcoStruxure IT Gateway.
  3. If you are trying to discover a Modbus TCP device, check the second box, Allow Schneider Electric to perform targeted reads on the following IP addresses or IP address ranges. List the IP addresses individually or specify a range.
When you confirm with device support that you have given your permission for a targeted read in the Device Support option in the Gateway, be sure to provide the following information for the devices you are trying to discover:
  • For a Modbus TCP device
    • IP address
    • Port number
    • Server address
  • For a Modbus serial device
    • Communication port
    • Server address
    • Baud Rate
    • Data Bits
    • Parity
    • Stop Bits
    • Flow Control
