Troubleshooting issues connecting your Gateway to EcoStruxure IT
Troubleshooting
How to troubleshoot and solve issues configuring the EcoStruxure IT Gateway
Select a Country
  • EcoStruxure IT Help Center
  • Gateway
  • Troubleshooting
  • Troubleshooting issues connecting your Gateway to EcoStruxure IT
  • Mark as Read
  • Gateway configuration file edit required after inc...
  • How to troubleshoot the Gateway connection to EcoS...
  • How to troubleshoot SNMP communication issues in t...
  • How to solve the cloud connectivity untrusted SSL ...
  • How to set up the Gateway proxy settings
  • How to restart the Gateway Service
  • How to replace the self-signed SSL certificate in ...
  • How to replace a device in EcoStruxure IT Gateway
  • How to disconnect or reconnect a Gateway from EcoS...
  • How to create a device walk file for EcoStruxure I...
  • How to allow a targeted read for Device Support
  • Gathering Gateway logs for troubleshooting
  • Gateway restore fails on some non-English locales
  • Gateway appliance network problems due to bad imag...
  • Gateway Device Communication Alert
  • Galaxy UPS is offline after updating the Gateway
  • Device serial numbers and unique identifiers
  • Device is offline after replacement or RMA
  • Device discover fails - SNMP is disabled by defaul...
  • Cannot discover Redfish devices in Gateway
  • Cannot discover NetBotz devices in Gateway
  • Web server port 443 is being used by another appli...
  • Troubleshooting issues connecting your Gateway to ...
  • Troubleshooting Gateway device discovery failure
  • SNMP walks, Modbus polls, and Redfish discoveries
  • NetBotz devices appear in the list of unknown devi...
  • NetBotz 4.x discovery issue when Gateway proxy set...
  • My device name didn't update in the Gateway after ...
  • My device is not responding - Gateway 1.4.0
EcoStruxure IT Support
Request Support
Back to Troubleshooting
  • Mark as Read
EcoStruxureIT
‎2018-11-13 06:29 AM
Last Updated: JLehr Champion ‎2026-06-12 04:06 AM
Common errors with possible causes and recommended actions to help you diagnose and solve issues connecting your Gateway to EcoStruxure IT
Connectivity error
Unable to resolve host name "{0}". Verify your DNS settings.
Make sure the DNS settings are properly configured in your Gateway server's network preferences.
Other well-known sites are reachable. Verify that "{0}" is not blocked by a network filter.
Consult with your IT department to ensure that the us.struxureon.com DNS entry or IP address is added to your firewall rules as they appear to be blocked.
Proxy configuration error
Proxy server "{0}" cannot be reached or is down.
Double check your proxy configuration settings and contact your IT department to verify the status of the proxy server and its configuration settings.
Proxy server name "{0}" cannot be resolved. Check your proxy settings.
Double check your proxy configuration settings and DNS settings and contact your IT department to verify the status of the proxy server and its configuration.
Auto-detection is enabled in your proxy settings but no proxies were detected. Try manually setting proxy.
If there is a network proxy between your Gateway server and the outside internet, please configure the proxy settings manually. You'll need the IP address of the proxy server and potentially a username and password if required by your proxy configuration. Your IT department should be able to help you acquire those if they are not directly accessible.
How to set up the EcoStruxure IT Gateway proxy settings
Proxy server authentication error
Proxy authentication failure. Check your proxy settings.
Confirm that you entered the correct username and password settings for your proxy server.
Connection refused
Also unable to reach other well-known sites. Check your network connection, or, possible firewall misconfiguration.
Consult with your IT department to ensure that your server is configured correctly to reach the outside internet. A network proxy or firewall could be blocking the connection.
Response timeout
Make sure you have a working network connection.
Forbidden
Received a forbidden response pointing to a possible proxy misconfiguration.
Verify that the time and date values of the operating system of the machine running the EcoStruxure IT Gateway server are properly set.
No route to host
Unable to reach configured router at {0}.
No route to host. Check your routing configuration.
Unknown host
Unable to resolve host names for any well-known sites: {0}. Verify your DNS settings.
Untrusted SSL certificate
Certificate is expired or untrusted. Common Name (CN) does not match the URL address.
Check the certificate details to see if it has expired.
The certificate might be in the wrong place in the file system.
If the certificate was issued by a trusted authority, you may need to install one or more intermediate certificates.
With assistance from your IT group, make sure the Certificate Authority used by the proxy is added to the Cloud connectivity > Proxy settings option in the Gateway user interface, or add us.struxureon.com to the exemption list so its traffic is not intercepted.
How to solve the Gateway untrusted certificate chain error
Invalid SSL certificate
The Gateway appears to be configured to use a proxy that is using SSL interception, and the Gateway does not trust the certificate the Proxy is replacing.
0% helpful (0/1)
Comments
iti
iti
Explorer
  • Mark as Read
‎2024-10-08 11:02 AM
