My device is not responding - Gateway 1.4.0
Troubleshooting
How to troubleshoot and solve issues configuring the EcoStruxure IT Gateway
  • EcoStruxure IT Help Center
  • Gateway
  • Troubleshooting
  • My device is not responding - Gateway 1.4.0
  • Mark as Read
  • How to troubleshoot the Gateway connection to EcoS...
  • How to troubleshoot SNMP communication issues in t...
  • How to solve the cloud connectivity untrusted SSL ...
  • How to set up the Gateway proxy settings
  • How to restart the Gateway Service
  • How to replace the self-signed SSL certificate in ...
  • How to replace a device in EcoStruxure IT Gateway
  • How to disconnect or reconnect a Gateway from EcoS...
  • How to create a device walk file for EcoStruxure I...
  • How to allow a targeted read for Device Support
  • Gathering Gateway logs for troubleshooting
  • Gateway restore fails on some non-English locales
  • Gateway appliance network problems due to bad imag...
  • Gateway Device Communication Alert
  • Galaxy UPS is offline after updating the Gateway
  • Device serial numbers and unique identifiers
  • Device is offline after replacement or RMA
  • Device discover fails - SNMP is disabled by defaul...
  • Cannot discover Redfish devices in Gateway
  • Cannot discover NetBotz devices in Gateway
  • Web server port 443 is being used by another appli...
  • Troubleshooting issues connecting your Gateway to ...
  • Troubleshooting Gateway device discovery failure
  • SNMP walks, Modbus polls, and Redfish discoveries
  • NetBotz devices appear in the list of unknown devi...
  • NetBotz 4.x discovery issue when Gateway proxy set...
  • My device name didn't update in the Gateway after ...
EcoStruxure IT Support
Request Support
Back to Troubleshooting
  • Mark as Read
Picard EcoStruxureIT
‎2018-11-15 09:27 AM
There is an intermittent issue in Gateway 1.4.0 where some or all devices report The <device> is not responding when they are actually online.
If you see this error, and you have confirmed the devices are online, check the log to confirm the error.
To confirm the error: Go to C:\Program Files\EcoStruxureITGateway\1.4.0\log on the computer where the gateway is installed, or log in to the gateway and download the console logs. Unzip the file and look at the newest console log.
This entry will appear in the gateway logs:
softwareVersion=1.4.0.68, originalMessage=protocol mapping error
com.se.dcl.ddf.MappingException: no protocol type: PreCompiledMapping{resource=URL [jar:file:C:\ProgramData\EcoStruxureITGateway\1.4.0\ddfs/ddf_bundle/default/se-ddf.jar!/ddf/SNMP/protocol.xml], signed=true}
Solution: Restart the EcoStruxure IT Gateway Service.
1. Go to Control Panel > Administrative Tools > Services.
2. Restart the EcoStruxure IT Gateway Server service.
This issue will be addressed in the next release.
