SNMP walks, Modbus polls, and Redfish discoveries
Troubleshooting
How to troubleshoot and solve issues configuring the EcoStruxure IT Gateway
  • EcoStruxure IT Help Center
  • Gateway
  • Troubleshooting
  • SNMP walks, Modbus polls, and Redfish discoveries
  • Mark as Read
  • How to troubleshoot the Gateway connection to EcoS...
  • How to troubleshoot SNMP communication issues in t...
  • How to solve the cloud connectivity untrusted SSL ...
  • How to set up the Gateway proxy settings
  • How to restart the Gateway Service
  • How to replace the self-signed SSL certificate in ...
  • How to replace a device in EcoStruxure IT Gateway
  • How to disconnect or reconnect a Gateway from EcoS...
  • How to create a device walk file for EcoStruxure I...
  • How to allow a targeted read for Device Support
  • Gathering Gateway logs for troubleshooting
  • Gateway restore fails on some non-English locales
  • Gateway appliance network problems due to bad imag...
  • Gateway Device Communication Alert
  • Galaxy UPS is offline after updating the Gateway
  • Device serial numbers and unique identifiers
  • Device is offline after replacement or RMA
  • Device discover fails - SNMP is disabled by defaul...
  • Cannot discover Redfish devices in Gateway
  • Cannot discover NetBotz devices in Gateway
  • Web server port 443 is being used by another appli...
  • Troubleshooting issues connecting your Gateway to ...
  • Troubleshooting Gateway device discovery failure
  • NetBotz devices appear in the list of unknown devi...
  • NetBotz 4.x discovery issue when Gateway proxy set...
  • My device name didn't update in the Gateway after ...
  • My device is not responding - Gateway 1.4.0
EcoStruxure IT Support
Request Support
Back to Troubleshooting
  • Mark as Read
Picard EcoStruxureIT
‎2020-02-07 07:29 AM
Schneider Electric has the ability to remotely initiate walks and polls of devices that are online and connected to a Gateway that is also online and registered with an EcoStruxure IT Expert organization.
Note: Before you request device support, try to discover the device in the Gateway.
The Gateway must be registered on EcoStruxure IT and online, and the device you want to monitor must be online.
When filing a ticket, make sure to provide the organization name or ID, and the IP address of the device so Schneider Electric support can locate the device.
For Modbus devices, you need to enable Schneider Electric's access to the device.  Those instructions are here.
