Gateway Device Communication Alert
Troubleshooting
How to troubleshoot and solve issues configuring the EcoStruxure IT Gateway
  • EcoStruxure IT Help Center
  • Gateway
  • Troubleshooting
  • Gateway Device Communication Alert
  • Mark as Read
  • How to troubleshoot the Gateway connection to EcoS...
  • How to troubleshoot SNMP communication issues in t...
  • How to solve the cloud connectivity untrusted SSL ...
  • How to set up the Gateway proxy settings
  • How to restart the Gateway Service
  • How to replace the self-signed SSL certificate in ...
  • How to replace a device in EcoStruxure IT Gateway
  • How to disconnect or reconnect a Gateway from EcoS...
  • How to create a device walk file for EcoStruxure I...
  • How to allow a targeted read for Device Support
  • Gathering Gateway logs for troubleshooting
  • Gateway restore fails on some non-English locales
  • Gateway appliance network problems due to bad imag...
  • Galaxy UPS is offline after updating the Gateway
  • Device serial numbers and unique identifiers
  • Device is offline after replacement or RMA
  • Device discover fails - SNMP is disabled by defaul...
  • Cannot discover Redfish devices in Gateway
  • Cannot discover NetBotz devices in Gateway
  • Web server port 443 is being used by another appli...
  • Troubleshooting issues connecting your Gateway to ...
  • Troubleshooting Gateway device discovery failure
  • SNMP walks, Modbus polls, and Redfish discoveries
  • NetBotz devices appear in the list of unknown devi...
  • NetBotz 4.x discovery issue when Gateway proxy set...
  • My device name didn't update in the Gateway after ...
  • My device is not responding - Gateway 1.4.0
EcoStruxure IT Support
Request Support
Back to Troubleshooting
  • Mark as Read
Picard EcoStruxureIT
‎2021-10-08 05:39 AM
When the Gateway is unable to keep up with the polling interval for a device, a Device Communication Alert warning alarm is generated. The alarm message is <device name> is responding slowly to polling.
The Device Communication Alert alarm is generated after five consecutive polls exceed the polling interval. The alarm clears after five consecutive polls complete within the polling interval.
You can do one or more of the following:
  • Reduce the number of devices the Gateway is polling at 1 minute (Gateway 1.13 and newer).
  • Reduce the number of devices the Gateway is polling.
  • Add more CPU and memory to the Gateway.
  • Investigate network latency issues, or put the Gateway on the same local area network (LAN) as the device.
Comments
P3WFMURAN8Q8PAM1B4XNK63N
Cadet
  • Mark as Read
‎2025-05-11 10:49 PM
My frequency converter communication alarm is not clearing
