Web server port 443 is being used by another application
Troubleshooting
How to troubleshoot and solve issues configuring the EcoStruxure IT Gateway
  • EcoStruxure IT Help Center
  • Gateway
  • Troubleshooting
  • Web server port 443 is being used by another application
  • Mark as Read
EcoStruxure IT Support
Request Support
Back to Troubleshooting
  • Mark as Read
Picard EcoStruxureIT
‎2020-05-04 08:29 AM
The Gateway is prevented from being installed or starting up when the web server port 443 is being used by another application.
To find the application using port 443:
On Windows, type the command:
netstat -aon | findstr 443
On Linux, type the command:
sudo netstat -tulpn | grep :443
 The last column of the output tells you which PID is listening on that port.
100% helpful (2/2)
