Gateway appliance network problems due to bad image
Troubleshooting
How to troubleshoot and solve issues configuring the EcoStruxure IT Gateway
  • EcoStruxure IT Help Center
  • Gateway
  • Troubleshooting
  • Gateway appliance network problems due to bad image
  • Mark as Read
  • How to troubleshoot the Gateway connection to EcoS...
  • How to troubleshoot SNMP communication issues in t...
  • How to solve the cloud connectivity untrusted SSL ...
  • How to set up the Gateway proxy settings
  • How to restart the Gateway Service
  • How to replace the self-signed SSL certificate in ...
  • How to replace a device in EcoStruxure IT Gateway
  • How to disconnect or reconnect a Gateway from EcoS...
  • How to create a device walk file for EcoStruxure I...
  • How to allow a targeted read for Device Support
  • Gathering Gateway logs for troubleshooting
  • Gateway restore fails on some non-English locales
  • Gateway appliance network problems due to bad imag...
  • Gateway Device Communication Alert
  • Galaxy UPS is offline after updating the Gateway
  • Device serial numbers and unique identifiers
  • Device is offline after replacement or RMA
  • Device discover fails - SNMP is disabled by defaul...
  • Cannot discover Redfish devices in Gateway
  • Cannot discover NetBotz devices in Gateway
  • Web server port 443 is being used by another appli...
  • Troubleshooting issues connecting your Gateway to ...
  • Troubleshooting Gateway device discovery failure
  • SNMP walks, Modbus polls, and Redfish discoveries
  • NetBotz devices appear in the list of unknown devi...
  • NetBotz 4.x discovery issue when Gateway proxy set...
  • My device name didn't update in the Gateway after ...
  • My device is not responding - Gateway 1.4.0
EcoStruxure IT Support
Request Support
Back to Troubleshooting
  • Mark as Read
Picard EcoStruxureIT
‎2020-12-18 02:10 AM
Some Gateway Appliances were shipped with bad ISO images. The networking functionality does not work properly on affected units.
Symptoms
  • A system plugged into LAN 2 is unable to receive a DHCP address
  • A system plugged into LAN 2 with a statically assigned IP is unable to reach Webmin
  • The appliance does not receive an IP address when connected on LAN1
Affected Units
Affected units were assembled in or prior to November 2019.  The assembled date is found on the package label.
What To Do
Contact Customer Support for assistance with this issue.
100% helpful (1/1)
