My device name didn't update in the Gateway after I changed it
Troubleshooting
How to troubleshoot and solve issues configuring the EcoStruxure IT Gateway
  • EcoStruxure IT Help Center
  • Gateway
  • Troubleshooting
  • My device name didn't update in the Gateway after I changed it
  • Mark as Read
  • How to troubleshoot the Gateway connection to EcoS...
  • How to troubleshoot SNMP communication issues in t...
  • How to solve the cloud connectivity untrusted SSL ...
  • How to set up the Gateway proxy settings
  • How to restart the Gateway Service
  • How to replace the self-signed SSL certificate in ...
  • How to replace a device in EcoStruxure IT Gateway
  • How to disconnect or reconnect a Gateway from EcoS...
  • How to create a device walk file for EcoStruxure I...
  • How to allow a targeted read for Device Support
  • Gathering Gateway logs for troubleshooting
  • Gateway restore fails on some non-English locales
  • Gateway appliance network problems due to bad imag...
  • Gateway Device Communication Alert
  • Galaxy UPS is offline after updating the Gateway
  • Device serial numbers and unique identifiers
  • Device is offline after replacement or RMA
  • Device discover fails - SNMP is disabled by defaul...
  • Cannot discover Redfish devices in Gateway
  • Cannot discover NetBotz devices in Gateway
  • Web server port 443 is being used by another appli...
  • Troubleshooting issues connecting your Gateway to ...
  • Troubleshooting Gateway device discovery failure
  • SNMP walks, Modbus polls, and Redfish discoveries
  • NetBotz devices appear in the list of unknown devi...
  • NetBotz 4.x discovery issue when Gateway proxy set...
  • My device name didn't update in the Gateway after ...
  • My device is not responding - Gateway 1.4.0
EcoStruxure IT Support
Request Support
Back to Troubleshooting
  • Mark as Read
Picard EcoStruxureIT
‎2020-05-28 07:59 AM
The device name is polled during the discovery process only, not during a regular polling period. If you change the name of a device after it has been discovered in the Gateway, the new name will not appear in the device list automatically.
To manually update device atrributes in Gateway versions 1.8.1 and later:
  1. Log in to the Gateway.
  2. Go to the device and click the Details tab.
  3. Click Retrieve details.
In previous Gateway versions, rediscover the device to update its name.
In general, static values for device attributes are only polled at discovery, for example, the items on the device details page. Sensor measurements are polled during the regular polling period.
100% helpful (1/1)
