How to create a device walk file for EcoStruxure IT Gateway and Data Center Expert
Troubleshooting
How to troubleshoot and solve issues configuring the EcoStruxure IT Gateway
  • EcoStruxure IT Help Center
  • Gateway
  • Troubleshooting
  • How to create a device walk file for EcoStruxure IT Gateway and Data Center Expert
  • Mark as Read
  • How to troubleshoot the Gateway connection to EcoS...
  • How to troubleshoot SNMP communication issues in t...
  • How to solve the cloud connectivity untrusted SSL ...
  • How to set up the Gateway proxy settings
  • How to restart the Gateway Service
  • How to replace the self-signed SSL certificate in ...
  • How to replace a device in EcoStruxure IT Gateway
  • How to disconnect or reconnect a Gateway from EcoS...
  • How to create a device walk file for EcoStruxure I...
  • How to allow a targeted read for Device Support
  • Gathering Gateway logs for troubleshooting
  • Gateway restore fails on some non-English locales
  • Gateway appliance network problems due to bad imag...
  • Gateway Device Communication Alert
  • Galaxy UPS is offline after updating the Gateway
  • Device serial numbers and unique identifiers
  • Device is offline after replacement or RMA
  • Device discover fails - SNMP is disabled by defaul...
  • Cannot discover Redfish devices in Gateway
  • Cannot discover NetBotz devices in Gateway
  • Web server port 443 is being used by another appli...
  • Troubleshooting issues connecting your Gateway to ...
  • Troubleshooting Gateway device discovery failure
  • SNMP walks, Modbus polls, and Redfish discoveries
  • NetBotz devices appear in the list of unknown devi...
  • NetBotz 4.x discovery issue when Gateway proxy set...
  • My device name didn't update in the Gateway after ...
  • My device is not responding - Gateway 1.4.0
EcoStruxure IT Support
Request Support
Back to Troubleshooting
  • Mark as Read
Picard EcoStruxureIT
‎2020-05-28 03:09 AM
Last Updated: Sisko JLehr Sisko ‎2025-06-20 09:17 AM
This tool can walk SNMP1, SNMP3, Modbus, Redfish, NetBotz, and FTP devices, gathering current values or files to facilitate DDF development or debugging for Data Center Expert or EcoStruxure IT Gateway.
Specific information about how to create a walk file for different DCE versions is here.
Modbus.org announced it is expunging all occurrences of inappropriate language of the query and response paradigm of Modbus communications. This tool was updated to comply as of version 1.9.1. More...
Requirements
  • Windows 10+ or Windows Server 2012+
  • Admin access to Command Line or Windows PowerShell
Getting started
1. Unzip the file walker_version_Windows.zip
2. Navigate to the folder you unzipped in step 1.  There should be a file called "walk.bat" in the folder.
3. Right click the file and click Open.
How to run your first command
Note: In Gateway 2.x, double dashes replaced single dashes in commands.
The general usage is:
<protocol> --ip <ip> <options>
Example: snmp --ip 192.169.0.10
Note: To read more about each command while you run the program, type help followed by the command you need help for. Example: help snmpv3
idea_icon_360009259237.pngidea_icon_360009259237.png There are several example commands below. Make sure to follow the structure carefully.
Running a command generates a walk file that is named using the IP address and a *.walk, *.json, *.txt", or *.xml extension. The file is saved to the folder where you ran the .bat script. If you are running a walk that retrieves raw files, such as FTP, these are saved as files.zip.
Example output: 192.169.0.10.xml
Example with file retrieval: 192.169.0.10.txt and files.zip
Troubleshooting
If you're having trouble connecting to a physical device, check with your network administrator to confirm that the device is enabled for the protocol and login credentials (if applicable) you are using to connect.
Device walks can take a long time to complete. A walk usually completes within 20 minutes for a slow connection.
If your walk fails to complete, it might be worth taking a break. Many protocols struggle to handle excessive repeated requests. If the walk seems to be hanging, try waiting a few hours and try again; this gives the device time to discard any old sessions and start accepting new ones. If the walk still fails, contact support for assistance.
If your Modbus poll output file does not get generated and you are running the walk.bat file as an administrator, try closing the program, right-click "walk.bat", and select "Open" (not "Run as administrator").
Usage details
SNMP V1
Defaults
-- ip: REQUIRED
-- port: 161
-- file: <ip>.walk
-- read: public
-- write: private
-- retries: 2
-- timeout: 5
-- enableBulkRequest: false
Examples
snmp --ip 192.169.0.10 -port 8161
snmp --ip 192.169.0.10 -read pass
SNMP V3
Argument valid values
-- authType: MD5, SHA
-- encType: DES, DES3, AES128, AES192, AES256
Defaults
-- ip: REQUIRED
-- port: 161
-- file: <ip>.walk
-- username: REQUIRED
-- authType:
-- authPassword:
-- encType:
-- encPassword:
-- retries: 2
-- timeout: 5
Examples
snmpv3 --ip 192.169.0.10 --port 161 --username XXXX --authType MD5 --authPassword XXXX --encType DES --encPassword XXXX
snmpv3 --ip 192.169.0.10 --port 161 --username XXXX --authType SHA --authPassword XXXX --encType AES128 --encPassword XXXX
Modbus
This requires a separate text file specifying which registers to read. See input.txt for formatting and examples.
WARNING: Excessive Modbus requests can overwhelm the device. Keep the number of selected registers as small as possible.
NOTE: The walker will output an XML file with the naming convention {ip_address}-{server_id}.xml (e.g., 12.34.56.789-1.xml). If this file does not get generated and you are running the walk.bat file as an administrator, try closing the program, right-click "walk.bat", and select "Open" (not "Run as administrator").
Defaults
-- <ip>: REQUIRED
-- port: 502
-- file:
-- server: 1
-- input: input.txt
-- maxReads: 100
-- walk: true
-- function:
-- start: 1
-- count:
-- print:
Examples
modbus --ip 192.169.0.10
modbus --ip 192.169.0.10 --port 5020 --server 2 --input registers.txt
Redfish
Defaults
-- ip: REQUIRED
-- port: 443
-- file: <ip>.json
-- password: REQUIRED
Example
redfish --ip 192.168.0.10 --username user1 --password pass
NetBotz
Defaults
-- ip: REQUIRED
-- port: 80
-- file: <ip>.json
-- username:
-- password:
-- useSSL: false
Examples
netbotz --ip 192.168.0.10 --username user1 --password pass
netbotz --ip 192.168.0.10 --username user1 --password pass --useSSL
FTP
Defaults
-- ip: REQUIRED
-- port: 21
-- file: <ip>.json
-- username:
-- password:
-- walk: true
-- download_file:
Example
ftp --ip 10.155.55.55 --username apc --password apc
100% helpful (1/1)
