How to replace a device in EcoStruxure IT Gateway
Troubleshooting
How to troubleshoot and solve issues configuring the EcoStruxure IT Gateway
  • EcoStruxure IT Help Center
  • Gateway
  • Troubleshooting
  • How to replace a device in EcoStruxure IT Gateway
  • Mark as Read
  • How to troubleshoot the Gateway connection to EcoS...
  • How to troubleshoot SNMP communication issues in t...
  • How to solve the cloud connectivity untrusted SSL ...
  • How to set up the Gateway proxy settings
  • How to restart the Gateway Service
  • How to replace the self-signed SSL certificate in ...
  • How to disconnect or reconnect a Gateway from EcoS...
  • How to create a device walk file for EcoStruxure I...
  • How to allow a targeted read for Device Support
  • Gathering Gateway logs for troubleshooting
  • Gateway restore fails on some non-English locales
  • Gateway appliance network problems due to bad imag...
  • Gateway Device Communication Alert
  • Galaxy UPS is offline after updating the Gateway
  • Device serial numbers and unique identifiers
  • Device is offline after replacement or RMA
  • Device discover fails - SNMP is disabled by defaul...
  • Cannot discover Redfish devices in Gateway
  • Cannot discover NetBotz devices in Gateway
  • Web server port 443 is being used by another appli...
  • Troubleshooting issues connecting your Gateway to ...
  • Troubleshooting Gateway device discovery failure
  • SNMP walks, Modbus polls, and Redfish discoveries
  • NetBotz devices appear in the list of unknown devi...
  • NetBotz 4.x discovery issue when Gateway proxy set...
  • My device name didn't update in the Gateway after ...
  • My device is not responding - Gateway 1.4.0
EcoStruxure IT Support
Request Support
Back to Troubleshooting
  • Mark as Read
Picard EcoStruxureIT
‎2020-10-13 05:28 AM
Last Updated: Sisko JLehr Sisko ‎2025-02-14 10:44 AM
If you need to replace a device that is monitored by the Gateway (RMA, for example), and you want to use the same IP address and credentials, you must log in to the Gateway and do the following:
  1. Delete the existing device. See how
  2. Run a discovery for the new device.
  3. Wait about 10 minutes for the device to start reporting data.
  4. Change the location of the device if necessary.
NOTE: The Gateway does not retain the sensor history for the device you replace.
It is important to delete the existing device first before you discover the new device because:
  • The Gateway may show the existing device as online even though it is no longer accessible because the new device will respond at that IP address.
  • The Gateway will show two devices at the same IP address, but only the new device updates sensor values.
  • When the next Gateway update is performed, the new device may be discovered automatically, and then the old device will show that it is offline.
