Video: Discover devices
Gateway software installation and setup
Step-by step instructions for how to download, install, and set up the EcoStruxure IT Gateway
  • EcoStruxure IT Help Center
  • Gateway
  • Gateway software installation and setup
  • Video: Discover devices
  • Mark as Read
  • Installing and setting up EcoStruxure IT Gateway
  • Discovering Smart-UPS in the Gateway
  • Import a device list to discover devices in EcoStr...
  • Configuring cloud connectivity in the Gateway
  • Set up redundant EcoStruxure IT Gateways
  • Installing the EcoStruxure IT mobile app
  • Updating EcoStruxure IT Gateway to the latest vers...
  • How to replace your EcoStruxure IT Gateway with a ...
  • Video: Install EcoStruxure IT Gateway on Linux
  • Installing EcoStruxure IT Gateway on CentOS no lon...
  • EcoStruxure IT Gateway installer checksums
  • Video: How to deploy EcoStruxure IT Gateway
  • Video: Install EcoStruxure IT Gateway on Windows
  • Video: How to discover Modbus devices in the Gatew...
EcoStruxure IT Support
Request Support
Back to Gateway software installation and setup
  • Mark as Read
Picard EcoStruxureIT
‎2019-04-04 03:58 AM
Last Updated: Sisko JLehr Sisko ‎2025-07-25 01:18 PM
Device credentials
During the initial setup of your Gateway, you specify credentials to communicate with the SNMPv1, SNMPv3, NetBotz, Redfish, or Modbus devices you want to discover. To modify these settings later, go to Settings > Device credentials.
See Installing and setting up EcoStruxure IT Gateway
Note: When AES is configured in the APC Network Management Card (NMC) interface, choose AES128 in the Gateway user interface.
Note: The EcoStruxure IT Gateway does not support SCP on APC NMC1 devices.
How to identify APC Network Management Card 1 (NMC1) devices
Note: When you discover NetBotz 300, 400, and 500 devices using SNMP, they are listed as unsupported devices in the Gateway. Use the NetBotz protocol to discover these devices in the Gateway.
Your APC NMC3 devices might be configured to limit the number of failed login attempts.
If the number of device file transfer credentials you provide in the Gateway exceeds the number of failed login attempts allowed on the NMC3 device, the device might be locked.
See New cybersecurity requirements in NMC3
Learn about how to discover Modbus Devices in IT Expert.
Discover devices
To discover devices after the initial setup of your Gateway:
  1. Go to Discover devices.
  2. Click Configure Credentials to select specific device file transfer credentials to use in a device discovery. Otherwise, all configured credentials will be used.
    Click Manage credentials to view the credentials you have configured in the Gateway.
    To comply with stricter cybersecurity requirements across various product groups, it is recommended that you review your username/password lists in EcoStruxure IT Gateway and confirm that configured credentials are both active and accurate.
  3. Specify the IP addresses or address range of the devices, or import a device list.
    You cannot import a device list for serial Modbus discoveries.
idea_icon_360021184553.pngidea_icon_360021184553.png Check out the on-screen device discovery tips.
Discovery results are displayed in the summary including discovered devices and unsupported devices that were not discovered. You can view details about unsupported devices, and see discovery results in the discovery log.
If you find that one or more of your devices is not supported, you can request device support.
All discovered devices are listed on the Devices page.
Need help configuring your APC NMC devices?
Need help configuring your NetBotz devices?
