Import a device list to discover devices in EcoStruxure IT Gateway
Gateway software installation and setup
Step-by step instructions for how to download, install, and set up the EcoStruxure IT Gateway
  • EcoStruxure IT Help Center
  • Gateway
  • Gateway software installation and setup
  • Import a device list to discover devices in EcoStruxure IT Gateway
  • Mark as Read
  • Installing and setting up EcoStruxure IT Gateway
  • Video: Discover devices
  • Discovering Smart-UPS in the Gateway
  • Import a device list to discover devices in EcoStr...
  • Configuring cloud connectivity in the Gateway
  • Set up redundant EcoStruxure IT Gateways
  • Installing the EcoStruxure IT mobile app
  • Updating EcoStruxure IT Gateway to the latest vers...
  • How to replace your EcoStruxure IT Gateway with a ...
  • Video: Install EcoStruxure IT Gateway on Linux
  • Installing EcoStruxure IT Gateway on CentOS no lon...
  • EcoStruxure IT Gateway installer checksums
  • Video: How to deploy EcoStruxure IT Gateway
  • Video: Install EcoStruxure IT Gateway on Windows
  • Video: How to discover Modbus devices in the Gatew...
EcoStruxure IT Support
Request Support
Back to Gateway software installation and setup
  • Mark as Read
Picard EcoStruxureIT
‎2020-03-30 06:44 AM
Last Updated: Sisko JLehr Sisko ‎2025-10-03 02:01 PM
You can import a device list from Data Center Expert or another source to easily discover devices in EcoStruxure IT Gateway.
Note: Gateway versions older than 1.15 do not allow discovery of SNMPv3 devices with the Authentication Passphrase and Privacy Passphrase set to None.
Note: APC NMC 4 (AP9644) devices are not yet supported.
File format
  • IP addresses to discover must be in a single column.
    For Modbus, IP addresses in one column and Server addresses in a second column for multiple Modbus devices of the same type, vendor, and family.
  • The columns do not need to be in any specific order.
  • Any extra columns are ignored.
  • The first row can optionally be a header row describing the contents of each column. A header row is not required.
  • The file extension must be .csv, .tsv, .txt
  • The column delimiter must one of the following: colon, comma, tab, pipe, semi-colon, space.
  • The character encoding on the file must be UTF-8.
Example
IP address
192.168.1.12
192.168.1.25
192.168.1.32
192.168.1.42
  1. On the Gateway Device discovery page, drag and drop a device list in .csv, .tsv, .txt format or click Import.
    GW18_discover_devices_1_import_360007175377.jpgGW18_discover_devices_1_import_360007175377.jpg
  2. Check the box if the first row in the file is a header row.
  3. Select the IP address column from the list. For Modbus discoveries, also select the Server address column from the list.
  4. Click show in the results section to verify that the file was imported as expected.
  5. Click Discover devices to begin the discovery.
SNMP, NetBotz, and Redfish
Modbus
You can import a device list that contains the IP addresses and server addresses for multiple Modbus TCP devices of the same type, vendor, and family.
GW_discover_Modbus_devices_from_import_360007175377.pngGW_discover_Modbus_devices_from_import_360007175377.png
