How to disconnect or reconnect a Gateway from EcoStruxure IT
Troubleshooting
How to troubleshoot and solve issues configuring the EcoStruxure IT Gateway
  • EcoStruxure IT Help Center
  • Gateway
  • Troubleshooting
  • How to disconnect or reconnect a Gateway from EcoStruxure IT
  • Mark as Read
  • How to troubleshoot the Gateway connection to EcoS...
  • How to troubleshoot SNMP communication issues in t...
  • How to solve the cloud connectivity untrusted SSL ...
  • How to set up the Gateway proxy settings
  • How to restart the Gateway Service
  • How to replace the self-signed SSL certificate in ...
  • How to replace a device in EcoStruxure IT Gateway
  • How to disconnect or reconnect a Gateway from EcoS...
  • How to create a device walk file for EcoStruxure I...
  • How to allow a targeted read for Device Support
  • Gathering Gateway logs for troubleshooting
  • Gateway restore fails on some non-English locales
  • Gateway appliance network problems due to bad imag...
  • Gateway Device Communication Alert
  • Galaxy UPS is offline after updating the Gateway
  • Device serial numbers and unique identifiers
  • Device is offline after replacement or RMA
  • Device discover fails - SNMP is disabled by defaul...
  • Cannot discover Redfish devices in Gateway
  • Cannot discover NetBotz devices in Gateway
  • Web server port 443 is being used by another appli...
  • Troubleshooting issues connecting your Gateway to ...
  • Troubleshooting Gateway device discovery failure
  • SNMP walks, Modbus polls, and Redfish discoveries
  • NetBotz devices appear in the list of unknown devi...
  • NetBotz 4.x discovery issue when Gateway proxy set...
  • My device name didn't update in the Gateway after ...
  • My device is not responding - Gateway 1.4.0
EcoStruxure IT Support
Request Support
Back to Troubleshooting
  • Mark as Read
Picard EcoStruxureIT
‎2018-11-15 09:21 AM
Reconnect a Gateway to EcoStruxure IT
  1. Log in to the Gateway you want to reconnect to EcoStruxure IT.
  2. Click EcoStruxure IT, and then click Register.
    GW_register_with_EcoStruxure_IT_360012117154.pngGW_register_with_EcoStruxure_IT_360012117154.png
  3. Log in to https://app.ecostruxureit.com/manage. Your registration code will be automatically entered.
  4. Specify a name for the Gateway and click Connect.
Disconnect a Gateway from EcoStruxure IT
  1. Go to https://app.ecostruxureit.com/manage and log in to EcoStruxure IT.
  2. Click Administration > Gateways and click the Gateway you want to disconnect.
  3. Click Disconnect, and confirm.
100% helpful (1/1)
