Troubleshooting Gateway device discovery failure
Troubleshooting
How to troubleshoot and solve issues configuring the EcoStruxure IT Gateway
  • EcoStruxure IT Help Center
  • Gateway
  • Troubleshooting
  • Troubleshooting Gateway device discovery failure
  • Mark as Read
  • How to troubleshoot the Gateway connection to EcoS...
  • How to troubleshoot SNMP communication issues in t...
  • How to solve the cloud connectivity untrusted SSL ...
  • How to set up the Gateway proxy settings
  • How to restart the Gateway Service
  • How to replace the self-signed SSL certificate in ...
  • How to replace a device in EcoStruxure IT Gateway
  • How to disconnect or reconnect a Gateway from EcoS...
  • How to create a device walk file for EcoStruxure I...
  • How to allow a targeted read for Device Support
  • Gathering Gateway logs for troubleshooting
  • Gateway restore fails on some non-English locales
  • Gateway appliance network problems due to bad imag...
  • Gateway Device Communication Alert
  • Galaxy UPS is offline after updating the Gateway
  • Device serial numbers and unique identifiers
  • Device is offline after replacement or RMA
  • Device discover fails - SNMP is disabled by defaul...
  • Cannot discover Redfish devices in Gateway
  • Cannot discover NetBotz devices in Gateway
  • Web server port 443 is being used by another appli...
  • Troubleshooting issues connecting your Gateway to ...
  • SNMP walks, Modbus polls, and Redfish discoveries
  • NetBotz devices appear in the list of unknown devi...
  • NetBotz 4.x discovery issue when Gateway proxy set...
  • My device name didn't update in the Gateway after ...
  • My device is not responding - Gateway 1.4.0
EcoStruxure IT Support
Request Support
Back to Troubleshooting
  • Mark as Read
Picard EcoStruxureIT
‎2019-09-16 03:10 AM
Last Updated: Sisko JLehr Sisko ‎2025-04-04 09:09 AM
A Gateway device discovery can fail for various reasons. After you run a discovery, open the Discovery Log to see the results for each device that was scanned.
Connection Failure
The Gateway was unable to communicate with the device. Check that the device and the discovery settings match for:
  • Protocol (SNMP vs Modbus)
  • IP Address
  • Port
  • Credentials (username, password, etc.)
APC network-enabled devices are being updated to improve security and comply with regulations.
New versions of APC Network Management Card (NMC) firmware will have the SNMP protocol disabled by default. Devices that have these cards cannot be discovered by EcoStruxure IT Expert or Data Center Expert until SNMP is enabled.
More information on specific changes
The <type> device was detected but is not supported
The Gateway was able to communicate with the device, but did not find a device definition file (DDF) that supports the device.
Request support for a new device
<type> device was detected but could not be uniquely identified
The device was detected and the Gateway has a DDF, but cannot get a unique identifier for the device.
Typically the Gateway tries to use the device's serial number as a unique identifier. For some devices, the serial number field is available but not set, such as:
  • Easy UPS 3s
  • Galaxy 5000 & 5500 device dependent
If possible, work with Technical Support to help you set the serial number.
Devices fall back to using the device MAC Address as a unique identifier if serial number is not available.
The <type> device has been successfully discovered
The device was discovered and will appear on the Devices page.
0% helpful (0/1)
