System requirements for EcoStruxure IT Gateway
System requirements
System requirements for EcoStruxure IT Gateway software including operating system, CPU and RAM, disk space, firewall, and supported browsers
  • EcoStruxure IT Help Center
  • Gateway
  • System requirements
  • System requirements for EcoStruxure IT Gateway
  • Mark as Read
  • Gateway default ports
EcoStruxure IT Support
Request Support
Back to System requirements
  • Mark as Read
Picard EcoStruxureIT
‎2018-11-13 05:56 AM
Last Updated: Sisko JLehr Sisko ‎2025-11-19 12:16 PM
Operating system
  • A server or PC that is always on with the most current version of:
    • English install of Microsoft® Windows® 10 and 11 64-bit, Server 2016, Server 2019, Server 2022, Server 2025
      Windows release information
    • Rocky Linux 8 and 9 (recommended)
      Rocky Linux release information
    • Red Hat Enterprise Linux 8 and 9 (recommended)
      RHEL release information
RHEL 7 and CentOS are not supported on Gateway 1.23 and newer.
How to replace your EcoStruxure IT Gateway with a new installation
EcoStruxure IT Gateway 1.23 release notes
It is recommended that operating systems and browsers are kept up to date and patched regularly in accordance to vendor recommendations.
User permissions
Windows
  • Local administrator permissions for clean install or manual update
  • The “Local System” account and “Network Services” account need permissions for running the Gateway software and performing an auto-update or an update initiated from ITE.
Linux
  • root or sudo capable user required for clean install or manual update
  • The root user and the non-login gateway user need permissions for running the Gateway software and performing an auto-update or an update initiated from ITE.
  • /etc/default/useradd must use the default /home directory. Otherwise, the install will fail.
  • The user running the Gateway installer must have file system privileges set to umask 0022 or 0002. Otherwise, the installer cannot initialize the database.
CPU and Memory
The required CPU and memory depends on the number of monitored devices and the protocol.
The following guidelines are based on our testing. Your actual results may vary due to differences in hardware, network, and device responsiveness.
The Gateway service (OpenJDK Platform binary) allocates up to half the total system memory for its use.
Recommended minimum CPU and memory
The number of SNMPv3 devices the Gateway can monitor is about 25% of what is possible with SNMPv1 and Modbus TCP.
Size Number of devices Number of sensors RAM CPU
Small 250 34,000 4GB 4
Medium 2000 270,000 8GB 8
Large 5000 540,000 16GB 24
SNMPv3
Small 60 8,500 4GB 4
Medium 500 65,000 8GB 8
Large 1,200 130,000 16GB 24
One Minute Polling
A maximum of 25 devices can be configured to poll at 1 minute.
When you use the small Gateway configuration to discover SNMPv3 devices, only about 10 out of the 60 SNMPv3 devices can be polled at 1 minute.  More than 10 devices may cause the Gateway to become overloaded and not keep up with the configured poll rate.
See Configure 1 minute polling in EcoStruxure IT Gateway
Alarms
If the combination of number of devices, poll rate, and protocol is more than the Gateway can handle, you may get a device communication alert alarm.
Disk Space
800MB of disk space is required for the application itself, plus additional space for a maximum of 8 days of sensor data.
Additional disk space required
Size Additional disk space Total disk space
Small 128MB per day 2GB
Medium 512MB per day 5GB
Large 1.1GB per day 10GB
Firewall
  • Port 443 TCP outbound
  • To connect using static IP addresses, add:
    • 40.84.62.190
    • 23.99.90.28
    • 52.230.227.202
    • 52.177.161.233
    • 52.154.163.222
If your firewall blocks the Gateway default ports, or any non-default ports you specified, you must add firewall exceptions for these ports. See Gateway default ports
DNS
A DNS server must be defined for the network that connects to EcoStruxure IT.
Make sure your Gateway can resolve us.ecostruxureit.com via DNS.
Make sure Gateway versions older than 1.10.0 can resolve us.struxureon.com via DNS.
Supported browsers
  • Microsoft Edge®
  • Mozilla® Firefox®
  • Google Chrome™
  • Safari
Set the screen resolution to at least 1024 x 768.
Smartphone
  • iPhone 6S and newer
  • iOS 13.0 and newer
  • Android 10 and newer
Connected devices
  • Intelligent Network Management Card
  • Modbus TCP or SNMP V1 and V3 enabled
    Gateway versions older than 1.15 do not allow discovery of SNMPv3 devices with the Authentication type and Encryption type set to None. See Discover devices
  • Connected to a TCP/IP network that the Gateway has access to
    Note: Firmware update and mass configuration with APC NMC 4 (AP9644) devices are not yet supported.
  • Redfish server protocol support
    • HP Proliant with iLO 4, 5
      Note: iLO 4 requires ManagerFirmwareVersion 2.55 or greater.
    • Dell PowerEdge with iDRAC 7, 8, 9
  • NetBotz support
    • Rack Monitor 570, 250, 750/755
Video clips (Beta) – Recommended camera limits
The number of cameras and their surveillance settings can impact system performance.
For the best experience, the following limits are recommended:
  • Medium or higher Gateway configuration: A maximum of 32 cameras with default NetBotz camera settings (1920x1080 and 10fps)
  • Organization-wide: A maximum of 250 cameras with default NetBotz camera settings (1920x1080 and 10fps)
Camera limits are not enforced by the system.
Recommended camera limits are based on performance considerations such as resolution, frame rate, and overall data volume.
Staying within these limits helps maintain stability and responsiveness.
Exceeding the recommended camera limits may reslt in degraded performance, especially during activities like backups or when additional devices are monitored.
Security certificate
When you launch the EcoStruxure IT Gateway, the browser might display a message that the connection is not secure. Since the application is installed on the local machine, the security certificate used by localhost is a self signed certificate.
It is safe to add an exception to your browser for https://localhost.
See How to replace the self-signed SSL certificate in EcoStruxure IT Gateway
100% helpful (4/4)
