EcoStruxure IT Gateway 1.23.x Release Notes
What's new in EcoStruxure IT Gateway
Get the latest news, release notes, and other need-to-know information about EcoStruxure IT Gateway
  • EcoStruxure IT Help Center
  • Gateway
  • What's new in EcoStruxure IT Gateway
  • EcoStruxure IT Gateway 1.23.x Release Notes
  • Mark as Read
EcoStruxure IT Support
Request Support
Back to What's new in EcoStruxure IT Gateway
  • Mark as Read
Sisko JLehr Sisko
‎2024-09-11 12:25 PM
The WMIC utility must be installed on new Windows 11 systems before you install EcoStruxure IT Gateway.
Note: Older Windows 11 versions that were updated to 24H2 may already have WMIC installed.
More...
Gateway 1.23.1
October 2024
Customers are encouraged to update their Gateway software to version 1.23.1.
To receive Gateway software updates promptly, enable auto-update.
See how...
  • This release replaces a certificate that enables device library updates.
    The Gateway must be at a minimum of version 1.23.1 to receive new device library updates.
    See How to update the Gateway device library
  • Important security updates
Gateway 1.23.0
September 2024
Two new state sensors
Two new sensors are displayed on the device's details page IT Expert.
Gateway Communication Status - protocol
This sensor is available for every discovered device: SNMP, Modbus, NetBotz, Redfish.
Example: Gateway communication status: NetBotz
Gateway File Transfer Status
This sensor is created when the communication protocol used by the device is available.
  • Protocol settings must be configured and enabled on the device.
  • Device communication settings configured on the Gateway and on the device must match.
If settings don't match or communication settings are not configured on either the device or the Gateway, the sensor is not created.
More...
IT Expert user configuration feature
This release supports the supports the APC NMC user configuration feature in IT Expert.
All the Gateways in your organization must be updated to at least version 1.23 to access this feature in IT Expert.
More...
RHEL 7 and CentOS 7 not supported
A update of PostgreSQL prevents EcoStruxure IT Gateway version 1.23 and newer from being installed on CentOS 7 or RHEL 7.
Attempts to update an existing Gateway to version 1.23 will fail.
For existing Gateway installations, deploy a new Gateway 1.23 on a supported Linux operating system. To retain sensor history, follow these instructions:
How to replace your EcoStruxure IT Gateway with a new installation
Software vulnerabilities fixed in Gateway 1.23
The following third-party components were updated to address these specific cybersecurity vulnerabilities:
Apache
  • CVE-2023-48795
PostgreSQL
  • CVE-2024-7348
This release also includes various additional component updates to improve overall security.
