How to update the Gateway device library
Gateway FAQ
Answers to common questions about the EcoStruxure IT Gateway
  • EcoStruxure IT Help Center
  • Gateway
  • Gateway FAQ
  • How to update the Gateway device library
  • Mark as Read
  • How to identify APC Network Management Card 1 (NMC...
  • Where is the registration code to connect the Gate...
  • Where can I find the Gateway discovery log?
  • Uniflair device discovery for EcoStruxure IT Gatew...
  • Ripple20 vulnerabilities in the Treck TCP/IP stack
  • Modbus gateways
  • How to reset the Gateway admin password in Gateway...
  • How to request device support for EcoStruxure IT G...
  • How to find the EcoStruxure IT Gateway serial numb...
  • How to discover a Uniflair cooling device - Gatewa...
  • How to discover NetBotz appliances in Gateway
  • How to connect to EcoStruxure IT using Data Center...
  • How to change device file transfer settings in the...
  • How can I see if my device is currently supported?
  • Gateway support for multiple network adapters
  • Gateway auto-update in IT Expert
  • EcoStruxure IT Gateway date and time settings
  • Do I need a dedicated server for EcoStruxure IT Ga...
  • Connecting a Smart-UPS to the Gateway with serial ...
  • Can the Gateway discover SmartConnect UPSs?
  • Can I change the default subnet for the Gateway ap...
  • Can EcoStruxure IT Gateway discover devices on the...
  • Modbus gateways
EcoStruxure IT Support
Request Support
Back to Gateway FAQ
  • Mark as Read
Picard EcoStruxureIT
‎2020-09-10 08:03 AM
Last Updated: Sisko JLehr Sisko ‎2025-05-22 01:59 PM
Device library updates are released frequently, independent from Gateway software releases.
See EcoStruxure IT Gateway device library release notes
NOTE: Updates to the Gateway device library are only available through EcoStruxure IT, not as a separate downloadable file.
Manually update Gateway DDFs
Gateways not configured for auto-update require an Administrator user to manually initiate the device library update in EcoStruxure IT.
Gateways configured for auto-update require an Administrator user to manually initiate the device library update when a new version of the device library is available independent of a Gateway software release.
Note: The Update button is not available when both the Gateway software and the device library are up to date.
  1. Log in and go to Administration > Gateways.
  2. Click Update on the Gateway's tile as you would for a Gateway software update.
You'll be prompted to install the type of update available, either a Gateway software update or a device library update.
The Gateway software update is always presented first. If a device library update is also available, it will be presented after the Gateway software is updated.
The new Gateway software version and/or the new device library version will appear on the Gateway's tile.
100% helpful (2/2)
