File transfer status sensor on EcoStruxure IT Gateway
Configuration
Detailed instructions for how to configure the EcoStruxure IT Gateway
  • EcoStruxure IT Help Center
  • Gateway
  • Configuration
  • File transfer status sensor on EcoStruxure IT Gateway
  • Mark as Read
  • File transfer status sensor on EcoStruxure IT Gate...
  • Video: Configure Gateway device file transfer sett...
  • Video: Configure device credentials in the Gateway
  • Configure Gateway device polling
  • Configure 1 minute polling in EcoStruxure IT Gatew...
  • Configure Gateway backup
  • Configure Gateway restore on Gateway 1.8+
  • Configuring Gateway backup in Gateway 1.7.0
  • Configure Gateway restore on Gateway 1.7.0
  • Configure SNMP trap ports
  • Trap receiver registration for third party devices
  • Configure SNMPv3 traps and informs in the Gateway
  • Connect PowerChute Business Edition agents (PCBE) ...
  • EcoStruxure IT Gateway logs
  • Configure Web credentials in the Gateway
EcoStruxure IT Support
Request Support
Back to Configuration
  • Mark as Read
Sisko JLehr Sisko
‎2025-06-16 02:08 PM
on ‎2025-06-16 02:08 PM
The file transfer status sensor is created and displayed on the Gateway when the communication protocol used by the device is available:
  • Protocol settings must be configured and enabled on the device.
  • Device communication settings configured on the device and on the Gateway must match.
If settings don't match or communication settings are not configured on either the device or the Gateway, this sensor is not created and is not displayed in the Gateway user interface.
After the device is discovered, this sensor value is updated in the Gateway when a file transfer action occurs in IT Expert including:
  • Firmware update
  • Device configuration
  • NMC user configuration
  • When the event log is retrieved (once a day)
Sensor status Meaning
OK Device is online as of the last file transfer action
Device is missing
Credentials do not match.
Credentials have changed on the device or on the Gateway.
Dash ( - )
Connection failed
Device communication lost
Sensor not supported
