Configure Gateway restore on Gateway 1.7.0
Configuration
Detailed instructions for how to configure the EcoStruxure IT Gateway
  • EcoStruxure IT Help Center
  • Gateway
  • Configuration
  • Configure Gateway restore on Gateway 1.7.0
  • Mark as Read
  • File transfer status sensor on EcoStruxure IT Gate...
  • Video: Configure Gateway device file transfer sett...
  • Video: Configure device credentials in the Gateway
  • Configure Gateway device polling
  • Configure 1 minute polling in EcoStruxure IT Gatew...
  • Configure Gateway backup
  • Configure Gateway restore on Gateway 1.8+
  • Configuring Gateway backup in Gateway 1.7.0
  • Configure SNMP trap ports
  • Trap receiver registration for third party devices
  • Configure SNMPv3 traps and informs in the Gateway
  • Connect PowerChute Business Edition agents (PCBE) ...
  • EcoStruxure IT Gateway logs
  • Configure Web credentials in the Gateway
EcoStruxure IT Support
Request Support
Back to Configuration
  • Mark as Read
Picard EcoStruxureIT
‎2019-01-31 03:45 AM
For configuring restore in Gateway 1.8 and newer, see Configure Gateway restore in Gateway 1.8
Backup files contain operating system-specific parameters. Restore a Windows system from a Windows backup, and a Linux system from a Linux backup.
IMPORTANT: You can restore a backup from the same version of Gateway only.
The backup keeps the existing Gateway serial number.
If you are using a proxy server, run this command before you run the restore:
SET _JAVA_OPTIONS=-Dhttp.proxyHost=x.x.x.x -Dhttp.proxyPort=443
Note: x.x.x.x is the IP address of the proxy server. You might also need to change the port if the proxy server is not at 443.
Windows restore
Restore is run from a Windows command prompt.
To restore from a previously created backup:
  1. Open a command prompt as administrator on the computer where the Gateway is installed.
  2. Navigate to C:\Program Files\EcoStruxure IT Gateway\x.x.x\restore
    Type the command cd C:\Program Files\EcoStruxure IT Gateway\x.x.x\restore
  3. Type the command restore.bat
    The utility searches for backups at the location you specify, and prompts you to choose the correct backup.
    After a series of confirmations, the restore process will begin.
When you do not add arguments to the command, all the possible arguments are displayed on the screen, including examples of how to execute the restore process.
Examples
restore.bat restore -serviceName EcoStruxureITGateway-1.7.0.64 -mntType WINDOWS_SHARE -server 1.2.3.4 -share backupShare -dir backupDir -domain aa.bb.com -user admin -pw -zipPw
Note: -user and -pw  and -zipPw are required. Specify the user for the file server.
You will be prompted for the backup location and the encrypted zipfile password after the command is run. The encrypted zipfile password is the serial number of your Gateway.
restore.bat password-reset
Note: This resets the Gateway admin user’s password. To reset the admin password, you must also go to Control Panel > Administrative Tools > Services and restart the EcoStruxure IT Gateway Server service.
Linux restore
  1. Open a command prompt on the computer where the Gateway is installed.
  2. Type the command cd /opt/EcoStruxureITGateway/x.x.x/restore
  3. Type the command ./restore.sh
Examples
./restore.sh restore -serviceName EcoStruxureITGateway-1.7.0.64 -mntType WINDOWS_SHARE -server 1.2.3.4 -share backupShare -dir backupDir -domain aa.bb.com -user admin -pw -zipPw
./restore.sh password-reset
Note: This resets the Gateway admin user’s password. To reset the admin password, you must also restart the EcoStruxure IT Gateway Server.  The command can be run from any directory by sudo users. Type systemctl restart EcoStruxureITGateway-x.x.x.service
Possible arguments
list List database backups
Usage: list [options]
Options:
-backup
backup to restore to
* -dir
backup directory on remote server
-domain
domain of remote server
* -mntType
mountType 'WINDOWS_SHARE'|'NFS'  Note: There is an issue using NFS shares for backup. Windows shares work as expected for the gateway installed on both Linux and Windows.
-pw
prompt for password for file server
-zipPw
prompt for encrypted zipfile password
* -server
remote backup server ip or name
* -share
remote mount point
-user
username for file server
restore Restore database
Usage: restore [options]
Options:
-backup
* -dir
-domain
* -mntType
-pw
-zipPw
* -server
* -share
remote mount point
-user
 password-reset Reset Gateway administrator password
Usage: password-reset [options]
