Configure Gateway restore on Gateway 1.8+
Configuration
Detailed instructions for how to configure the EcoStruxure IT Gateway
  • EcoStruxure IT Help Center
  • Gateway
  • Configuration
  • Configure Gateway restore on Gateway 1.8+
  • Mark as Read
  • File transfer status sensor on EcoStruxure IT Gate...
  • Video: Configure Gateway device file transfer sett...
  • Video: Configure device credentials in the Gateway
  • Configure Gateway device polling
  • Configure 1 minute polling in EcoStruxure IT Gatew...
  • Configure Gateway backup
  • Configuring Gateway backup in Gateway 1.7.0
  • Configure Gateway restore on Gateway 1.7.0
  • Configure SNMP trap ports
  • Trap receiver registration for third party devices
  • Configure SNMPv3 traps and informs in the Gateway
  • Connect PowerChute Business Edition agents (PCBE) ...
  • EcoStruxure IT Gateway logs
  • Configure Web credentials in the Gateway
EcoStruxure IT Support
Request Support
Back to Configuration
  • Mark as Read
Picard EcoStruxureIT
‎2020-03-27 05:35 AM
Last Updated: Sisko JLehr Sisko ‎2024-03-29 06:39 AM
Restoring a Gateway configuration from backup is performed via the command line. You must have console access to the Gateway server, either locally or via a remote terminal, for example, SSH.
IMPORTANT: You can restore a backup from the same version of Gateway only.
Restore from backup
Note: This example is on a Windows based system. The Linux commands are identical; the install directory is slightly different. Sudo can be used to run with administrator level privileges.  On Linux, if an incorrect password is supplied, the terminal will hang.  Press Ctrl-C to exit and retry the command with a different password.
  1. Open a command prompt as administrator on the computer where the Gateway is installed.
  2. Navigate to the bin subdirectory within Gateway install directory on the file system, for example, C:\Program Files\EcoStruxure IT Gateway\<version number>\bin
  3. Type the command ./restore
  4. You will be prompted to choose a backup (based on id) from those found in the local file system under the backups subdirectory in the Gateway install directory, for example, C:\Program Files\EcoStruxure IT Gateway\<version number>\backups
  5. After entering the backup id, you will be prompted for the password set at backup creation time to decrypt the backup contents.
    Note: Backups created in Gateway version 1.7 use the serial number of the Gateway server for the password.
  6. After successfully entering the password, you will be prompted to confirm your choice and proceed. This initiates the Gateway configuration restore procedure. The Gateway application will restart.
