Configure Web credentials in the Gateway
Configuration
Detailed instructions for how to configure the EcoStruxure IT Gateway
Send InviteCancel
Physical security: NetBotz 750/755 video clips in IT Expert
Gateway version 2.1 will support this feature. Release is pending.
ConfigureWebcredentials in the Gateway to retrieve video clips from NetBotz 75x surveillance cameras in IT Expert.
NetBotz 75x video clips are available on the Physical security page in IT Expert whenat least oneof the Gateways in your organization is updated to version 2.1 or newer.
Log in to the Gateway, and go toSettings>Device credentials.
In theWeb Credentialssection, click New web credentialsto create settings, or click the tiles for the existing settings to modify them.
