Video: Configure device credentials in the Gateway
Configuration
Detailed instructions for how to configure the EcoStruxure IT Gateway
  • EcoStruxure IT Help Center
  • Gateway
  • Configuration
  • Video: Configure device credentials in the Gateway
  • Mark as Read
  • File transfer status sensor on EcoStruxure IT Gate...
  • Video: Configure Gateway device file transfer sett...
  • Configure Gateway device polling
  • Configure 1 minute polling in EcoStruxure IT Gatew...
  • Configure Gateway backup
  • Configure Gateway restore on Gateway 1.8+
  • Configuring Gateway backup in Gateway 1.7.0
  • Configure Gateway restore on Gateway 1.7.0
  • Configure SNMP trap ports
  • Trap receiver registration for third party devices
  • Configure SNMPv3 traps and informs in the Gateway
  • Connect PowerChute Business Edition agents (PCBE) ...
  • EcoStruxure IT Gateway logs
  • Configure Web credentials in the Gateway
EcoStruxure IT Support
Request Support
Back to Configuration
  • Mark as Read
Sisko JLehr Sisko
‎2024-08-14 08:29 AM
During the initial setup of your Gateway, you specify the device credentials used to access SNMPv1 and SNMPv3 devices, NetBotz, and Redfish devices. These settings are used by EcoStruxure IT Gateway to discover and poll devices.
You can reuse these credentials for all your device discoveries and add additional credentials as needed.
  1. Log in to the Gateway. Go to Settings > Device Credentials. Click New device credentials and select the communication protocol used by your devices.
  2. Specify a label that allows you to identify the credential along with the following settings depending on what protocol you selected. Click Create setting.
    • SNMPv1: Specify the Read community name (public is default), the Write community name (private is default), and the port, (161 is default).
    • SNMPv3: Specify the Username, Authentication type (MD5 or SHA), Authentication password, Encryption type (DES, DES3, AES128, AES192, AES256), Encryption password, and Port (161 is default).
      When AES is configured in the APC Network Management Card (NMC) interface, choose AES128 in the Gateway user interface.
      EcoStruxure IT Gateway versions older than 1.15 do not allow discovery of SNMPv3 devices with the Authentication type or Encryption type set to None.
      Need help configuring your APC NMC devices?
  3. Rediscover the device(s). Verify the devices are communicating.
    See Discover devices
  4. Delete the old device credentials if they are no longer being used by any devices.
