Gateway default ports
System requirements
System requirements for EcoStruxure IT Gateway software including operating system, CPU and RAM, disk space, firewall, and supported browsers
  • EcoStruxure IT Help Center
  • Gateway
  • System requirements
  • Gateway default ports
  • Mark as Read
EcoStruxure IT Support
Request Support
Back to System requirements
  • Mark as Read
Picard EcoStruxureIT
‎2019-02-15 05:29 AM
If your firewall blocks the Gateway default ports listed here, or any non-default ports you specified, you must add firewall exceptions for these ports.
The information in this article pertains to the latest version of EcoStruxure IT Gateway.
Web server
Communication between the Gateway and your web browser on the intranet uses the following port:
Name Port Direction Type Description
Web server 443 INBOUND TCP Web browser access to Gateway interface
You can specify the ports used by the Gateway web server when you install the Gateway software.
Device communication
Communication between the Gateway and your devices on the intranet uses the following ports:
FTP 21 OUTBOUND TCP Transfer device configurations, firmware binaries, and logs
SCP 22 OUTBOUND TCP Transfer device configurations, firmware binaries, and logs
SNMP 161 OUTBOUND UDP SNMP device polling and discovery
  1062 INBOUND UDP
SNMP traps
  162 INBOUND UDP
SNMP traps (default for most third party devices)
  8011 INBOUND TCP HTTP Service log capture (available on select devices)
NetBotz HTTPS 443 OUTBOUND TCP HTTPS NetBotz device polling and discovery
  8453 INBOUND TCP HTTPS NetBotz traps
NetBotz HTTP 80 OUTBOUND TCP HTTP NetBotz device polling and discovery
  8010 INBOUND TCP HTTP NetBotz traps
Modbus TCP 502 OUTBOUND TCP Modbus TCP device polling and discovery
Redfish 443 OUTBOUND TCP Redfish server polling and discovery
See Configure SNMP trap ports
EcoStruxure IT communication
Communication between the Gateway and EcoStruxure IT over the internet uses the following port.
EcoStruxure IT 443 OUTBOUND TCP EcoStruxure IT Gateway communication with EcoStruxure IT cloud.
Local system only
Firewalls do NOT need to open external access to these ports. This information is provided to help avoid port conflicts.
Database port 5432 INBOUND TCP Local System ONLY - Used by the Gateway software to communicate with its database.
Note: The database port is subject to change on software update. A free port is automatically selected for the database during the update process.
Gateway appliance specific
Gateway appliance version 1.10 and newer
Gateway 22 INBOUND TCP Gateway application command line interface access
Gateway 2222 INBOUND TCP
For support use only
Gateway appliance OS command line interface access via SSH
Note: You must first access the Gateway CLI from the appliance private network on port 22 to enable the SSHD service, and then follow the instructions provided by support.
See Gateway appliance command line interface (CLI) - version 1.10 and newer
See EcoStruxure IT Gateway appliance installation and setup - version 1.10 and newer for more information.
Gateway appliance version 1.9 and older
Communication between the Gateway appliance's Webmin interface and your web browser.
Note: Webmin is only accessible from the private network of the Gateway appliance.
Webmin 10000 INBOUND TCP Web browser access to the Gateway appliance's Webmin setup and configuration interface.
See EcoStruxure IT Gateway appliance installation - version 1.9.0 and older for more information.
More information
In addition to the firewall of your host system, your IT department might have firewalls and proxies in place that could prevent Gateway from communicating with EcoStruxure IT or your devices.
Contact your IT department if they are running firewalls that are blocking required ports.
If your organization uses a proxy, see the instructions in these articles for configuring the Gateway:
Installing and setting up EcoStruxure IT Gateway
