Gateway appliance command line interface (CLI) - version 1.10 and newer
EcoStruxure IT Gateway appliance
Support for EcoStruxure IT Gateway Appliances ends in December 2023. Learn how you can migrate to a new installation of the Gateway software.
  • EcoStruxure IT Help Center
  • Gateway
  • EcoStruxure IT Gateway appliance
  • Gateway appliance command line interface (CLI) - version 1.10 and newer
  • Mark as Read
  • Replacing your EcoStruxure IT Gateway appliance
  • What's new in the EcoStruxure IT Gateway appliance
  • How to reset a lost administrator password for the...
  • Troubleshooting tips for mounting a filesystem usi...
  • Mount a remote filesystem on the Gateway appliance...
  • Managing DHCP on the Gateway appliance private net...
  • How to set a static IP address on the public netwo...
  • How to set a static IP address on the private netw...
  • How to restart the DCHP server on a Gateway applia...
  • How to resolve Gateway appliance cloud connectivit...
  • Gateway appliance management options - version 1.1...
  • Gateway appliance command line interface (CLI) - v...
  • Configure backup on a Gateway appliance - version ...
  • EcoStruxure IT Gateway appliance known issues
EcoStruxure IT Support
Request Support
Back to EcoStruxure IT Gateway appliance
  • Mark as Read
Picard EcoStruxureIT
‎2021-02-19 04:37 AM
Private network
There are several options in the Gateway application private network command line interface (CLI) to help you manage your Gateway server.
This command line interface allows you to manage specific operating system and Gateway application settings; it does not give you direct access to the operating system for the Gateway appliance.
CLI access to the Gateway appliance OS is available with assistance from customer support only.
Note: The CLI on the Gateway public network allows you to reboot the Gateway appliance and view status only.
To access the private network CLI:
  1. Connect a computer to the same private network as the Gateway appliance.
  2. Use an SSH client to log in to the Gateway command line interface (CLI) using your user credentials, default ssh port 22.
idea_icon_360017797957.pngidea_icon_360017797957.png Press Tab after a command to see command suggestions.
Built in commands
clear: Clear the shell screen.
exit or quit: Exit the shell
stacktrace: Display the full stacktrace of the last error
versions: Display version information
Backup/restore commands
backup config: View or configure backup settings
backup list: List backups
backup run: Run a backup now
backup schedule: Configure a system schedule to run backups at a regular interval
restore: Restore the Gateway from backup
DHCP server commands
dhcp config: Configures the DHCP server
dhcp leases: Show the DHCP server leases
dhcp service: Controls the DHCP service
dhcp status: Show the DHCP server configuration and status
NTP commands
ntp config: Configures the NTP service
ntp service: Controls the NTP service
ntp sources: Reports the number of NTP servers and peers that are online and offline
ntp sourcestats: Displays information about the drift rate and offset estimation process for each NTP source
ntp status: Displays the current NTP service status
ntp tracking: Displays parameters about the system clock performance
Gateway appliance commands
appliance config: List appliance configurations
appliance reboot: Reboot the Gateway appliance
appliance reset: Reset the Gateway appliance to factory defaults
appliance shutdown: Shut down the Gateway appliance
File system commands
fs config: Show mounted filesystems
fs mount: Mount remote filesystem (to configure remote backups)
fs show: Show NFS or SAMBA mounts available to the appliance from a remote host
fs unmount: Unmount a mounted remote filesystem
Gateway commands
gateway config: Display the current configuration values of the installed Gateway
gateway install: Install the Gateway service, if not already installed
gateway status: Display current status of the Gateway
gateway uninstall: Remove the Gateway service
Network commands
net config: Configure private or public network DNS and IP addresses
net status: Display the status of both the public and private networks
OS commands
nslookup: nslookup
ping: ping
traceroute: traceroute
view log: Page through or follow the tail of a log file
Shell help
help: Display help
SSHD commands
Accessed with assistance from technical support only
sshd service: Controls the SSHD service
sshd status: Show the SSHD configuration and status
User account commands
change password: Change the password of the user logged into the CLI
Public network
You can access the Gateway application CLI from the public network to reboot the Gateway appliance, view DHCP leases, and see various status. You must use the CLI from the private network to execute other commands.
To access the CLI from the public network:
Use an SSH client to log in to the Gateway CLI using its public IP address and your user credentials, default ssh port 22.
Built in commands
dhcp leases: show the DHCP server leases
dhcp status: show the DHCP server configuration and status
ntp commands
ntp status: displays the current NTP service status
appliance commands
gateway commands
gateway status: Display current status of the Gateway service
network commands
shell help
help: Display help
sshd commands
sshd status: Shows the technical support SSHD service configuration and status
0% helpful (0/1)
