How to replace your EcoStruxure IT Gateway with a new installation
Gateway software installation and setup
Step-by step instructions for how to download, install, and set up the EcoStruxure IT Gateway
  • EcoStruxure IT Help Center
  • Gateway
  • Gateway software installation and setup
  • How to replace your EcoStruxure IT Gateway with a new installation
  • Mark as Read
  • Installing and setting up EcoStruxure IT Gateway
  • Video: Discover devices
  • Discovering Smart-UPS in the Gateway
  • Import a device list to discover devices in EcoStr...
  • Configuring cloud connectivity in the Gateway
  • Set up redundant EcoStruxure IT Gateways
  • Installing the EcoStruxure IT mobile app
  • Updating EcoStruxure IT Gateway to the latest vers...
  • How to replace your EcoStruxure IT Gateway with a ...
  • Video: Install EcoStruxure IT Gateway on Linux
  • Installing EcoStruxure IT Gateway on CentOS no lon...
  • EcoStruxure IT Gateway installer checksums
  • Video: How to deploy EcoStruxure IT Gateway
  • Video: Install EcoStruxure IT Gateway on Windows
  • Video: How to discover Modbus devices in the Gatew...
EcoStruxure IT Support
Request Support
Back to Gateway software installation and setup
  • Mark as Read
Picard EcoStruxureIT
‎2023-04-24 06:34 AM
Last Updated: Sisko JLehr Sisko ‎2025-02-06 10:54 AM
Use this procedure to replace an EcoStruxure IT Gateway and maintain sensor history.
  • Replace a Gateway appliance due to its end-of-life in December, 2023
  • Replace a Gateway software installation on CentOS 7
    CentOS 7 end of life is June, 2024
    CentOS 7 is not supported on Gateway 1.23 and newer.
  • Replace a software Gateway installation on RHEL 7
    RHEL 7 is not supported on Gateway 1.23 and newer.
  • Replace a Gateway for disaster recovery
  • Any other scenario where a new Gateway must be deployed
IMPORTANT: Do not remove the existing installation of the Gateway from your organization until you have discovered all your devices in the new installation and connected the new Gateway to IT Expert.
To replace your Gateway:
  1. Set up a new software Gateway according to system requirements.
    System requirements for EcoStruxure IT Gateway
  2. Install the Gateway software.
  3. Discover your devices.
    10743026713501_10582437370781.png10743026713501_10582437370781.png Export your device list to CSV from the EcoStruxure IT cloud, then import the list in Gateway discovery.  See how...
  4. Log in to IT Expert as an existing customer.
    Go to Administration > Gateways to connect the new Gateway to your organization.
  5. Delete the old Gateway from your organization.
  6. Decommission your old Gateway installation.
See also
Replacing your EcoStruxure IT Gateway appliance
