Set up redundant EcoStruxure IT Gateways
Gateway software installation and setup
Step-by step instructions for how to download, install, and set up the EcoStruxure IT Gateway
Send InviteCancel
Redundant EcoStruxure IT Gateways can reduce latency for organizations that have multiple locations or in large installations. There is no charge for additional Gateways.
@TiffaniAlvarez, Gateways do not communicate to each other. Each gateway communicates to the Schneider Electric cloud as outlined in the diagram above. Gateways can monitor the same devices as another gateway, usually to ensure redundancy, but each gateway is maintained separately and pushes data to the cloud separately from each other.
