EcoStruxure IT Gateway installer checksums
Gateway software installation and setup
Step-by step instructions for how to download, install, and set up the EcoStruxure IT Gateway
  • EcoStruxure IT Help Center
  • Gateway
  • Gateway software installation and setup
  • EcoStruxure IT Gateway installer checksums
  • Mark as Read
EcoStruxure IT Support
Request Support
Back to Gateway software installation and setup
  • Mark as Read
Picard EcoStruxureIT
‎2019-08-14 01:39 AM
Last Updated: Sisko JLehr Sisko ‎2024-10-02 02:04 PM
You can verify the EcoStruxure IT Gateway installer SHA1 checksum on a Mac, Windows, or Linux computer.
DO NOT run the installer if your calculated value does not match the published checksum for your Gateway version and operating system.
Verify from Windows PowerShell
  1. Download the EcoStruxure IT Gateway installer to your Windows machine.
  2. Open PowerShell. The PowerShell.exe command starts a session in a command window.
  3. Navigate to the directory containing the downloaded file.
  4. Use the Get-FileHash PowerShell command to calculate the SHA1 checksum of the installer and compare it against the published value in the table.
    Get-FileHash -Path .\EcoStruxureITGateway-x.x.x.x-windows.exe -Algorithm SHA1
Verify from a Linux terminal
  1. Download the EcoStruxure IT Gateway installer to your CentOS or RHEL machine.
  2. Open a terminal window.
  4. Use the sha1sum terminal command to calculate the SHA1 checksum of the installer and compare it against the published value.
    sha1sum EcoStruxureITGateway-x.x.x.x-linux-x64.run
Verify from a Mac terminal
  1. Download the EcoStruxure IT Gateway installer to your Mac OS machine.
  4. Use the shasum terminal command to calculate the installer SHA1 checksum and compare it against the published checksum in the table.
    shasum EcoStruxureITGateway-x.x.x.x-windows.exe
System requirements for EcoStruxure IT Gateway
