Discovering Smart-UPS in the Gateway
Gateway software installation and setup
Step-by step instructions for how to download, install, and set up the EcoStruxure IT Gateway
  • EcoStruxure IT Help Center
  • Gateway
  • Gateway software installation and setup
  • Discovering Smart-UPS in the Gateway
  • Mark as Read
  • Installing and setting up EcoStruxure IT Gateway
  • Video: Discover devices
  • Import a device list to discover devices in EcoStr...
  • Configuring cloud connectivity in the Gateway
  • Set up redundant EcoStruxure IT Gateways
  • Installing the EcoStruxure IT mobile app
  • Updating EcoStruxure IT Gateway to the latest vers...
  • How to replace your EcoStruxure IT Gateway with a ...
  • Video: Install EcoStruxure IT Gateway on Linux
  • Installing EcoStruxure IT Gateway on CentOS no lon...
  • EcoStruxure IT Gateway installer checksums
  • Video: How to deploy EcoStruxure IT Gateway
  • Video: Install EcoStruxure IT Gateway on Windows
  • Video: How to discover Modbus devices in the Gatew...
EcoStruxure IT Support
Request Support
Back to Gateway software installation and setup
  • Mark as Read
Picard EcoStruxureIT
‎2020-08-19 08:30 AM
Last Updated: Sisko JLehr Sisko ‎2023-09-29 01:03 PM
Discovering Smart-UPS using a Network Management Card (NMC)
If the Smart-UPS connects to your network using a Network Management Card (NMC), you can discover it in the EcoStruxure IT Gateway using SNMPv1 or SNMPv3.
Do not use the ethernet port on the UPS to connect to EcoStruxure IT if the UPS uses an NMC.
Discovering Smart-UPS via Modbus
Smart-UPS models starting with SMT, SMTL750, and SMTL1000 support Modbus TCP using the ethernet port on the UPS with firmware version 4.2 and greater.
NOTE: Modbus TCP discoveries are supported on EcoStruxure IT Gateway version 1.9.0 and newer.
See Installing and setting up EcoStruxure IT Gateway
