Metering & Power Quality
  • EcoStruxure Power & Grid
  • Mark all as New
  • Mark all as Read
  • Float this item to the top
  • Invite a Friend
  • Threaded format
  • Linear Format
  • Sort by Topic Start Date
The message you are trying to access is permanently deleted.
Top Labels
Top Labels
  • Alphabetical
  • ION Setup 226
  • Power Quality 216
  • PM8000 203
  • ION9000 176
  • PM5000 175
  • Insulation Monitoring 135
  • ION7000 74
  • ION8000 68
  • PowerTag Energy 54
  • PM Announcements 40
  • Did you know 40
  • iEM3000 29
  • HDPM6000 27
  • PM Guidebooks 16
  • PM3000 16
  • PM Downloads 14
  • ION Guidebooks 11
  • iEM2000 10
  • ION Downloads 8
  • Commissioning 1
  • Communicating Actuators and Energy Valves 1
  • varplus 1
  • troubleshooting 1
  • Previous
  • 1 of 3
  • Next
Charles_Murison
Picard Charles_Murison Picard
526
Mehran_Mehrnia
Admiral Mehran_Mehrnia Admiral
138
Ramasamy_N
Captain Ramasamy_N Captain
115
Thumbnail of PowerLogic ION9000
PowerLogic ION9000
53
Thumbnail of PowerLogic ION8650 series
PowerLogic
45
Thumbnail of PowerLogic PM5000 series
43
Load more
  • All
  • Solved
  • Unsolved
  • Unanswered
Sanjeet_Sahota
Lt. Commander Sanjeet_Sahota Lt. Commander
Firmware Version V4.6.0 Now Available for ION9000, PM8000, and ION7400
Introducing the latest release of firmware version 4.6.0 for the PowerLogic™ Advanced Meters. This update brings several significant enhancements to improve functionality and security. Here are the top...
EcoStruxure Power & Grid icon_circle Metering & Power Quality
3972 4 15
Latest Reply: Charles_Murison
sesa351067_brid
Lt. Commander sesa351067_brid Lt. Commander
New URLS for ION9000, PM8000, and ION7400 online help
The HEP meters have new URLs for the online version of help. Please use (and bookmark!) the new URLs going forward. The old ones will be taken down on September 30th. Meter New URL Old URL ...
2967 5 5
Latest Reply: Romain_Polette
Informational
Maaz
Ensign Maaz Ensign
Welcome & Get Started to Metering & Power Quality Forum!
--> Discover an optimized power & energy monitoring architecture for building energy efficiency and major contents not to miss What is Metering & Power Quality Forum about? This foru...
3050 2 0
2022-10-13
sesa351067_brid
Technical Documentation Feedback
The Technical Communications Team is committed to making the Advanced Power Meter technical information easier to use and find. You can help us improve the usability and quality of our content by sha...
3249 1 3
Maaz
Ensign Maaz Ensign
PowerLogic™ ION9000 officially certified as a class 0.1S device
We’re thrilled to announce that in addition to its certification as a Power Quality Instrument Class A (PQI-A) – the PowerLogic™ ION9000 is now officially certified as a Class 0.1S accurate device, ...
5055 5 1
Sanjeet_Sahota
ION8650 Firmware - Hashes and Files
Hello All In an effort to provide more ways to validate that the file you are using to upgrade your meter I have created this table of hashes of the firmware for our released file. Firmware V...
7199 3 1
Paul_Crouch
Crewman Paul_Crouch
PQM HTML Webpage Comtrade file time stamp
When I view the Comtrade waveform on the HTML page, the time stamp is UTC time. If I were to view the same waveform file in ION setup it has the proper time stamp for the region and time the meter is ...
34 0 1
Chen-Leo_Liang
Crewman Chen-Leo_Liang
ION template compare
Hello SE Experts, I used Notepad++ to compare two ION templates and I can see there are some differences, but it’s not fully clear to me what each difference represents. Difference 1: Difference 2...
52 0 1
Stuart_Cheng
Lt. Commander Stuart_Cheng Lt. Commander
ION Meter Setpoint Module – Setup Register Read/Write via Modbus
Hi All, I’m using the setpoint module on an ION meter to configure some alarms. I’m wondering if the setpoint high/low limits are available for read and write via Modbus? I tried setting up a ...
105 0 5
dave_torevell_s
Ensign dave_torevell_s Ensign
iEM2455 Modbus Communications
Hi Everyone, Hoping somebody can help with the configuration of the worst Schneider meter i have ever tried to set up, aside from the terrible capacitive buttons on the front these meters will talk via...
54 0 1
Latest Reply: Sidharthan
Bjenkins
Lieutenant | EcoXpert Master Bjenkins Lieutenant | EcoXpert Master
PM5700 BACnet not linked when de-energised?
We have a site with MDB with multiple Schneider PM series meters (5700 and 5500). The issue is we are picking up these meters over BACnetIP. As there are some spare meters not energised, we have no con...
73 0 3
c_e
c_e
PMxxxx Offline configuration
Hello, Is it possible to backup/restore a PM5000 device using the ION Setup software? Additionally - is it possible to configure a device offline? The ION Setup Help keeps referring to a .exe file...
66 0 2
sergiotusen
sergiotusen Cadet
PQM 8000 Model: METSEPM8210
We are working with OKKEN panels in a Data Center and are experiencing intermittent communication failures across multiple LV OKKEN skids. The panels operate normally, but communication is randomly los...
70 0 2
Latest Reply: Mehran_Mehrnia
Paul_de_Jong
Paul_de_Jong
Power Quality Interruption
We have the above alarm in PME, does anyone know how this occurs and how it can be resolved?
45 0 1
Aaron_G
Aaron_G
AccuSine FW 3.1.0 - Upgrade Tool Malfunctioning
With the latest 3.1.0 FW for AccuSine+, I'm finding that the only way the Active Filter Upgrade tool works is by going through Update Tool 003.001.000\Data64\program files\Active Filter\UpdateTool. Ho...
83 1 1
Latest Reply: Yan_Zhang
AdrianTirta
Crewman AdrianTirta
Modbus Setting EM2357
Dear Expert, I'm working on a project that uses the EM2357 as the energy meter. I’ve already established communication through the Modbus RS-485 port, with a PAS800L gateway at the end of the daisy c...
198 0 6
Latest Reply: akash_das
Tomohiro-Okada
Lieutenant Tomohiro-Okada
Regarding the installatoin of the HDPM6000 head unit(single phase)
Hi, I use the HDPM6000 head unit in split (2-phase) mode. In this setup, I originally wired the main CTs as follows: Main CT for phase R → 1A (black), 1A (white)Main CT for phase N → 1N (black), ...
373 0 8
Latest Reply: Tomohiro-Okada
  • « Previous
    • 1
    • 2
    • 3
    • 223
  • Next »
