Troubleshooting DCE backups
DCE FAQ
  • EcoStruxure IT Help Center
  • DCE FAQ
  • Troubleshooting DCE backups
  • Mark as Read
  • What happens if my DCE subscription license expire...
  • Is a disaster recovery solution available for Data...
  • Data Center Expert REST API
  • APC Worldwide Customer Support
  • Data Center Expert sensor loading times at login
  • Data Center Expert client launcher does not reopen...
  • DCE 7.9.3 to 8.0 server update progress in the web...
  • Changing the protocol used to monitor APC SNMP dev...
  • Change the IP address of a discovered device
  • Hi! Hello! Welcome to the EcoStruxure IT Help Cent...
  • Say hello to EcoStruxure IT Expert!
  • Where can I download the Data Center Expert firmwa...
  • Unplugged sensors in DCE 7.4.3
  • Uniflair DDF identification guide for Data Center ...
  • NetBotz 750 discovery error
  • Launch to Device does not work for NMC 1 devices o...
  • How to verify the checksum for the DCE update file
  • How to verify device support for DCE
  • How to reset the DCE Administrator password for th...
  • How to request a DDF
  • How to increase RAM (memory) or CPU (processors) o...
  • How to create a device walk file for Data Center E...
  • How to create a Windows share
  • How to add a private network (second network adapt...
  • Devices disappear after upgrading DCE to version 7...
  • Carel pCOWeb cards
EcoStruxure IT Support
Request Support
Back to DCE FAQ
  • Mark as Read
Picard EcoStruxureIT
‎2020-07-28 07:31 AM
Last Updated: Sisko JLehr Sisko ‎2024-09-24 12:25 PM
DCE backups do not overwrite one another. A share may eventually get too full to accommodate more backups.
You cannot delete backups that exist on a share from the DCE client. You must access the shared drive/folder directly to delete old backups or add space to the current allocation if more space is required.
SMBv2 and higher support
Server Message Block (SMB) v2 and v3 are supported in Data Center Expert 7.9.0 and newer.
Data Center Expert 7.8.1 and older do not support SMB versions higher than version 1.
Note: To backup DCE 7.8.1 to restore on DCE 7.9.0, you must use SMBv1.
Microsoft began disabling SMBv1 in Windows Updates. This can cause DCE 7.8.1 and older to be unable to back up to existing shares or mount new shares.
More information about enabling SMBv1
NTLMv2 support
Data Center Expert versions before 7.3.1 do not support mounting to shares that require NTLMv2 authentication.
In some situations, the test mount might be successful, but does not authenticate. For DCE 7.3.1 and older, you must use a share that allows NTLMv1 authentication.
Contact your local technical support to verify your software support and get update links.
FIPS mode
Data Center Expert versions 8.2.0 and newer support FIPS mode.
CIFS (Windows) mounts do not work when FIPS mode is enabled.
MD5 authentication is required for CIFS, which is not supported in FIPS mode.
See Server access
Messages
No remote resource provided
Failed to mount remote share
The selected backup is not a valid backup.
The selected backup is not complete.
The selected backup does not match the running version.
This backup was created with different hardware than the hardware your EcoStruxure IT Data Center Expert server is currently running. Are you sure you want to restore from the backup?
See
How to perform a backup in DCE
Complete update process for DCE
