How to perform a backup in DCE
Storage settings
Send InviteCancel
Log in to the DCE desktop client and go to System > Server Administration Settings > Server Backup/Restore.
Click Add Backup.
Click Windows Share and Next.
Fill in the required information:
Server Hostname or IP address: Enter the IP address of the system that contains the Windows share. Hostname can be used if DNS is configured in System > Server Administration Settings > Network Settings.
Username: User that has read/write permission to the Windows share
Password/Verify Password: Password of the user defined in the username field
Domain: If the computer is on a domain, enter the domain name or workgroup name as seen in Control panel > System.
Share: Name of the Windows share
Subdirectory: If a subdirectory was created in the Windows share (not required)
Security: On Data Center Expert version 7.3.1 and higher, the share security can be defined. Below v7.3.1 only NTMLv1 is allowed.
Click Test Mount. If successful, you’ll see a message that the share was mounted successfully. Click Next.
Specify that the backup be performed at specific times on certain days of the week if desired. Click Finish.
Select the backup in the list and then click Start Backup.
You can continue to use the system during the backup process. When the backup finishes, you’ll see the last backup finish date and last result of the backup.
