Change the IP address of a discovered device
DCE FAQ
  • EcoStruxure IT Help Center
  • DCE FAQ
  • Change the IP address of a discovered device
  • Mark as Read
  • What happens if my DCE subscription license expire...
  • Is a disaster recovery solution available for Data...
  • Data Center Expert REST API
  • APC Worldwide Customer Support
  • Data Center Expert sensor loading times at login
  • Data Center Expert client launcher does not reopen...
  • DCE 7.9.3 to 8.0 server update progress in the web...
  • Changing the protocol used to monitor APC SNMP dev...
  • Hi! Hello! Welcome to the EcoStruxure IT Help Cent...
  • Say hello to EcoStruxure IT Expert!
  • Where can I download the Data Center Expert firmwa...
  • Unplugged sensors in DCE 7.4.3
  • Uniflair DDF identification guide for Data Center ...
  • Troubleshooting DCE backups
  • NetBotz 750 discovery error
  • Launch to Device does not work for NMC 1 devices o...
  • How to verify the checksum for the DCE update file
  • How to verify device support for DCE
  • How to reset the DCE Administrator password for th...
  • How to request a DDF
  • How to increase RAM (memory) or CPU (processors) o...
  • How to create a device walk file for Data Center E...
  • How to create a Windows share
  • How to add a private network (second network adapt...
  • Devices disappear after upgrading DCE to version 7...
  • Carel pCOWeb cards
EcoStruxure IT Support
Request Support
Back to DCE FAQ
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:13 AM
In DCE 7.6.0 and higher, you can change the IP address of a discovered device without losing any data.
After you change the IP address on the Network Management Card:
  1. Go to the Device > SNMP Device Communication Settings > Device Scan Settings option.
  2. Select a device, then select Edit Device Scan Settings.
  3. Change the IP address listed there.
50% helpful (1/2)
