Launch to Device does not work for NMC 1 devices on the DCE private network
DCE FAQ
  • EcoStruxure IT Help Center
  • DCE FAQ
  • Launch to Device does not work for NMC 1 devices on the DCE private network
  • Mark as Read
  • What happens if my DCE subscription license expire...
  • Is a disaster recovery solution available for Data...
  • Data Center Expert REST API
  • APC Worldwide Customer Support
  • Data Center Expert sensor loading times at login
  • Data Center Expert client launcher does not reopen...
  • DCE 7.9.3 to 8.0 server update progress in the web...
  • Changing the protocol used to monitor APC SNMP dev...
  • Change the IP address of a discovered device
  • Hi! Hello! Welcome to the EcoStruxure IT Help Cent...
  • Say hello to EcoStruxure IT Expert!
  • Where can I download the Data Center Expert firmwa...
  • Unplugged sensors in DCE 7.4.3
  • Uniflair DDF identification guide for Data Center ...
  • Troubleshooting DCE backups
  • NetBotz 750 discovery error
  • Launch to Device does not work for NMC 1 devices o...
  • How to verify the checksum for the DCE update file
  • How to verify device support for DCE
  • How to reset the DCE Administrator password for th...
  • How to request a DDF
  • How to increase RAM (memory) or CPU (processors) o...
  • How to create a device walk file for Data Center E...
  • How to create a Windows share
  • How to add a private network (second network adapt...
  • Devices disappear after upgrading DCE to version 7...
  • Carel pCOWeb cards
EcoStruxure IT Support
Request Support
Back to DCE FAQ
  • Mark as Read
Picard EcoStruxureIT
‎2022-09-26 05:53 AM
Last Updated: Sisko JLehr Sisko ‎2024-07-11 08:10 AM
In DCE 7.9.0 and newer, the Launch to Device option does not work for NMC 1 devices that use HTTPS on the DCE private network.
Connect a computer to the DCE private network to directly access the device's web user interface.
NMC 1 does not support SSL protocols more recent than TLS 1.0. Updated security policies introduced in DCE 7.9.0 do not include TLS 1.0. The option to choose between TLS versions was removed from DCE for security reasons.
Sensor information, alarms, alarm notification, graphing, etc. for NMC 1 devices are not affected since they do not rely on web functionality.
This applies to devices with NMC 1 (AP9617, AP9618, AP9619) and devices with an embedded NMC 1 including, but not limited to: Metered/Switched Rack PDUs (AP78XX, AP79XX); Rack Automatic Transfer Switches (AP77XX); Environmental Monitoring Units (AP9320, AP9340, NetBotz 200).
See Known issues in DCE
