NetBotz 750 discovery error
DCE FAQ
  • EcoStruxure IT Help Center
  • DCE FAQ
  • NetBotz 750 discovery error
  • Mark as Read
  • What happens if my DCE subscription license expire...
  • Is a disaster recovery solution available for Data...
  • Data Center Expert REST API
  • APC Worldwide Customer Support
  • Data Center Expert sensor loading times at login
  • Data Center Expert client launcher does not reopen...
  • DCE 7.9.3 to 8.0 server update progress in the web...
  • Changing the protocol used to monitor APC SNMP dev...
  • Change the IP address of a discovered device
  • Hi! Hello! Welcome to the EcoStruxure IT Help Cent...
  • Say hello to EcoStruxure IT Expert!
  • Where can I download the Data Center Expert firmwa...
  • Unplugged sensors in DCE 7.4.3
  • Uniflair DDF identification guide for Data Center ...
  • Troubleshooting DCE backups
  • Launch to Device does not work for NMC 1 devices o...
  • How to verify the checksum for the DCE update file
  • How to verify device support for DCE
  • How to reset the DCE Administrator password for th...
  • How to request a DDF
  • How to increase RAM (memory) or CPU (processors) o...
  • How to create a device walk file for Data Center E...
  • How to create a Windows share
  • How to add a private network (second network adapt...
  • Devices disappear after upgrading DCE to version 7...
  • Carel pCOWeb cards
EcoStruxure IT Support
Request Support
Back to DCE FAQ
  • Mark as Read
Picard EcoStruxureIT
‎2021-01-19 12:45 AM
Device status may be inaccurate because an attempt to transfer a device definition file (DDF) failed
If you have followed the instructions in NetBotz 750 appliance discovery process in DCE and the error has not cleared:
Ping from the DCE server to the NetBotz 750.
If ping fails, allow or enable ICMP in your firewall from the DCE server IP address to the NetBotz 750 IP address.
You might need to rediscover the device in DCE.
For best results, update your DCE and NetBotz 750 to the latest versions.
Comments
adamhinchliff
adamhinchliff
Cadet
  • Mark as Read
‎2025-08-27 09:28 PM
This does not solve the issue.
Admiral
  • Mark as Read
‎2025-09-03 07:55 AM
@adamhinchliff,  I recommend reaching out to technical support to troubleshoot if you are having this issue and the above steps does not resolve it.
