How to verify the checksum for the DCE update file
DCE FAQ
Select a Country
  • EcoStruxure IT Help Center
  • DCE FAQ
  • How to verify the checksum for the DCE update file
  • Mark as Read
  • How to create a device walk file for Data Center E...
  • How to request a DDF
  • Carel pCOWeb cards
  • What happens if my DCE subscription license expire...
  • Troubleshooting DCE backups
  • Where can I download the Data Center Expert firmwa...
  • Is a disaster recovery solution available for Data...
  • Where can I see DCE server appliance specification...
  • Uniflair DDF identification guide for Data Center ...
  • How to reset the DCE Administrator password for th...
  • How to create a Windows share
  • How to verify device support for DCE
  • Launch to Device does not work for NMC 1 devices o...
  • Data Center Expert sensor loading times at login
  • Data Center Expert client launcher does not reopen...
  • DCE 7.9.3 to 8.0 server update progress in the web...
  • Changing the protocol used to monitor APC SNMP dev...
  • Change the IP address of a discovered device
  • APC Worldwide Customer Support
  • Unplugged sensors in DCE 7.4.3
  • NetBotz 750 discovery error
  • Say hello to EcoStruxure IT Expert!
  • How to increase RAM (memory) or CPU (processors) o...
  • Devices disappear after upgrading DCE to version 7...
  • How to add a private network (second network adapt...
  • Hi! Hello! Welcome to the EcoStruxure IT Help Cent...
  • Updated firmware available for APC Rack PDU 2G (AP...
EcoStruxure IT Support
Request Support
Back to DCE FAQ
  • Mark as Read
EcoStruxureIT
‎2020-07-28 02:55 AM
Last Updated: JLehr Champion ‎2024-09-26 12:44 PM
Verify the Data Center Expert installer checksum on a Windows or Linux computer before you use it to perform a software update.
DO NOT run the installer if your calculated value does not match the published checksum for your DCE version and operating system.
Note: DCE 8.2.0 and newer use a SHA256 checksum. Previous versions use SHA1 or MD5.
Verify from Windows PowerShell
  1. Download the Data Center Expert upgrade.zip file to your Windows machine.
  2. Open PowerShell. The PowerShell.exe command starts a session in a command window.
  3. Navigate to the directory containing the downloaded .zip file.
  4. Use the Get-FileHash PowerShell command to calculate the SHA256 checksum of the file and compare it against the published value in the table.
    Get-FileHash -Path .\upgrade-xxx.xx.zip -Algorithm SHA256
Verify from a Linux terminal
  1. Download the Data Center Expert upgrade.zip file to your CentOS or RHEL machine.
  2. Open a terminal window.
  4. Use the sha256sum terminal command to calculate the SHA256 checksum of the installer and compare it against the published value.
    sha256sum upgrade.zip
See Complete update process for DCE
