How to create a Windows share
DCE FAQ
  • EcoStruxure IT Help Center
  • DCE FAQ
  • How to create a Windows share
  • Mark as Read
  • What happens if my DCE subscription license expire...
  • Is a disaster recovery solution available for Data...
  • Data Center Expert REST API
  • APC Worldwide Customer Support
  • Data Center Expert sensor loading times at login
  • Data Center Expert client launcher does not reopen...
  • DCE 7.9.3 to 8.0 server update progress in the web...
  • Changing the protocol used to monitor APC SNMP dev...
  • Change the IP address of a discovered device
  • Hi! Hello! Welcome to the EcoStruxure IT Help Cent...
  • Say hello to EcoStruxure IT Expert!
  • Where can I download the Data Center Expert firmwa...
  • Unplugged sensors in DCE 7.4.3
  • Uniflair DDF identification guide for Data Center ...
  • Troubleshooting DCE backups
  • NetBotz 750 discovery error
  • Launch to Device does not work for NMC 1 devices o...
  • How to verify the checksum for the DCE update file
  • How to verify device support for DCE
  • How to reset the DCE Administrator password for th...
  • How to request a DDF
  • How to increase RAM (memory) or CPU (processors) o...
  • How to create a device walk file for Data Center E...
  • How to add a private network (second network adapt...
  • Devices disappear after upgrading DCE to version 7...
  • Carel pCOWeb cards
EcoStruxure IT Support
Request Support
Back to DCE FAQ
  • Mark as Read
Picard EcoStruxureIT
‎2020-07-28 05:39 AM
Last Updated: Sisko JLehr Sisko ‎2024-09-24 12:18 PM
NTLM and SMB versions may prevent a Windows share from being mounted.
In DCE, CIFS (Windows) mounts do not work when FIPS mode is enabled.
MD5 authentication is required for CIFS, which is not supported in FIPS mode.
See Server access
Having problems? See Troubleshooting DCE backups
  1. Create a folder on the Windows system that you want to be the backup destination.
  2. Right-click the folder and select Properties.
  3. Select the Sharing, and then Share.
  4. Add the specific user you want DCE to use to store the backup.
  5. Set the user's permission level to be Read/Write.
  6. Click Share.
  7. Select Advanced Sharing.
  8. Make sure the Share this folder checkbox is checked, and then select Permissions.
  9. Add the specific user that you want DCE to use to connect to this share (same user as step 5).
  10. Set the user permissions for Full Control.  Click Apply and OK.
    NOTE: You will need the share name, IP address of the Windows system the share is stored on, and the credentials for the user you granted full control.
See
How to perform a backup in DCE
Complete update process for DCE
