How to add a private network (second network adapter) to a DCE VM
DCE FAQ
  • EcoStruxure IT Help Center
  • DCE FAQ
  • How to add a private network (second network adapter) to a DCE VM
  • Mark as Read
  • What happens if my DCE subscription license expire...
  • Is a disaster recovery solution available for Data...
  • Data Center Expert REST API
  • APC Worldwide Customer Support
  • Data Center Expert sensor loading times at login
  • Data Center Expert client launcher does not reopen...
  • DCE 7.9.3 to 8.0 server update progress in the web...
  • Changing the protocol used to monitor APC SNMP dev...
  • Change the IP address of a discovered device
  • Hi! Hello! Welcome to the EcoStruxure IT Help Cent...
  • Say hello to EcoStruxure IT Expert!
  • Where can I download the Data Center Expert firmwa...
  • Unplugged sensors in DCE 7.4.3
  • Uniflair DDF identification guide for Data Center ...
  • Troubleshooting DCE backups
  • NetBotz 750 discovery error
  • Launch to Device does not work for NMC 1 devices o...
  • How to verify the checksum for the DCE update file
  • How to verify device support for DCE
  • How to reset the DCE Administrator password for th...
  • How to request a DDF
  • How to increase RAM (memory) or CPU (processors) o...
  • How to create a device walk file for Data Center E...
  • How to create a Windows share
  • How to add a private network (second network adapt...
  • Devices disappear after upgrading DCE to version 7...
  • Carel pCOWeb cards
EcoStruxure IT Support
Request Support
Back to DCE FAQ
  • Mark as Read
Picard EcoStruxureIT
‎2020-07-28 04:50 AM
  1. Gracefully shut down the DCE virtual appliance: In the DCE desktop client, go to File > Shut down server.
  2. In your vSphere (VMware) virtual server settings, select the option to add a network adapter.
  3. Specify the type and the network connection. Make sure this connection is mapped correctly, particularly when the DHCP server will be enabled on the private network interface.
  4. Save the settings and power on the virtual appliance.
  5. Log into the vSphere console for the DCE virtual appliance using the following credentials (default, but can be changed):
    Username: apcsetup
    Password: apcsetup
  6. Within five (5) seconds, press m to modify the settings.
  7. Accept the settings that were previously configured, or modify the settings if needed.
  8. Press y to accept the Enable private network interface option.
  9. Specify whether you want to enable the DHCP server on the private network interface.
See Complete update process for DCE
