Unplugged sensors in DCE 7.4.3
DCE FAQ
Send InviteCancel
Device Definition Files (DDF) were updated in Data Center Expert 7.4.3 to address a recently discovered issue in Data Center Expert v7.4.0, v7.4.1, and v7.4.2. Earlier Data Center Expert versions are not affected.
Affected devices have duplicate sensor entries in Data Center Expert, with sensor status reported as unplugged.
The values for the following sensors could not be corrected, causing some sensors to report as unplugged in DCE 7.4.3.
You can delete the unplugged sensors, but historical sensor data will be lost. Otherwise, you can leave the sensor in the unplugged state to maintain historical data. Contact your local technical support if you have questions about a specific sensor value.
Sensor
Model affected*
Number of External Battery Packs
Smart-UPS 1500/3000
Battery Current
Symmetra PX 250/500 and Galaxy VM/VX 3-phase UPS
(Main/Bypass) Input Apparent Power - Phase (1-3)
(Main/Bypass) Input Power - Phase (1-3)
(Main/Bypass) Input Current Phase - (1-3)
Smart-UPS VT/RT, Symmetra PX, Silcon and Galaxy 3-phase UPS
(Main/Bypass) Input Apparent Power Total
Symmetra PX, Symmetra 250/500 UPS, and Silcon UPS
Output Power VA - Phase (1-3)
