Changing the protocol used to monitor APC SNMP devices
DCE FAQ
  • EcoStruxure IT Help Center
  • DCE FAQ
  • Changing the protocol used to monitor APC SNMP devices
  • Mark as Read
  • What happens if my DCE subscription license expire...
  • Is a disaster recovery solution available for Data...
  • Data Center Expert REST API
  • APC Worldwide Customer Support
  • Data Center Expert sensor loading times at login
  • Data Center Expert client launcher does not reopen...
  • DCE 7.9.3 to 8.0 server update progress in the web...
  • Changing the protocol used to monitor APC SNMP dev...
  • Change the IP address of a discovered device
  • Hi! Hello! Welcome to the EcoStruxure IT Help Cent...
  • Say hello to EcoStruxure IT Expert!
  • Where can I download the Data Center Expert firmwa...
  • Unplugged sensors in DCE 7.4.3
  • Uniflair DDF identification guide for Data Center ...
  • Troubleshooting DCE backups
  • NetBotz 750 discovery error
  • Launch to Device does not work for NMC 1 devices o...
  • How to verify the checksum for the DCE update file
  • How to verify device support for DCE
  • How to reset the DCE Administrator password for th...
  • How to request a DDF
  • How to increase RAM (memory) or CPU (processors) o...
  • How to create a device walk file for Data Center E...
  • How to create a Windows share
  • How to add a private network (second network adapt...
  • Devices disappear after upgrading DCE to version 7...
  • Carel pCOWeb cards
EcoStruxure IT Support
Request Support
Back to DCE FAQ
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:13 AM
You can change the protocol only on APC SNMPv1 devices that support SNMPv3. For information about whether an APC SNMP device supports SNMPv3, consult the device documentation.
Before you begin, it is recommended you view and confirm the devices you want to convert from SNMPv1 to SNMPv3 in the "Device Scan Settings" display, accessed from the SNMP Device Communication Settings option in the Device menu.
  1. Select the APC SNMP Device Configuration option in the Device menu.
  2. Select Configure Devices.
  3. Select the APC SNMPv3 device you want to use as the source.
  4. Click Retrieve Device Settings.
  5. Click Next to select the devices you want to convert to SNMPv3.
    To ensure only the devices you want to convert to SNMPv3 are selected, you can checkmark Select/Deselect All to clear the list, then checkmark the devices to include.
  6. Expand SNMPv1 Settings and checkmark the Access option.
  7. Double-click the Access option under SNMPv1 Settings, or select the Access option and click Edit, to change its setting to Disabled, if necessary.
  8. Uncheck Authentication options 1 - 4, if necessary.
  9. Expand the SNMPv3 Settings option.
  10. Double-click the Access option under SNMPv3 Settings, or select the Access option and click Edit, to change its setting to Enabled, if necessary.
  11. Expand the Authentication options 1 - 4 you want to use, select the Access option under each option, and click Edit, to change its setting to Enabled, if necessary.
  12. Checkmark other available options to change their settings, if necessary.
    The security settings on some target devices might require setting user passwords, authentication phrases, and encryption phrases manually at the device user interface.
  13. Click Finish.
You can monitor progress applying the settings to the selected devices in the Device Configuration Status view, accessed from the Device option in the Window menu.
