Data Center Expert client launcher does not reopen after server changes
DCE FAQ
Select a Country
  • EcoStruxure IT Help Center
  • DCE FAQ
  • Data Center Expert client launcher does not reopen after server changes
  • Mark as Read
  • How to create a device walk file for Data Center E...
  • How to request a DDF
  • Carel pCOWeb cards
  • What happens if my DCE subscription license expire...
  • Troubleshooting DCE backups
  • Where can I download the Data Center Expert firmwa...
  • Is a disaster recovery solution available for Data...
  • Where can I see DCE server appliance specification...
  • Uniflair DDF identification guide for Data Center ...
  • How to reset the DCE Administrator password for th...
  • How to create a Windows share
  • How to verify the checksum for the DCE update file
  • How to verify device support for DCE
  • Launch to Device does not work for NMC 1 devices o...
  • Data Center Expert sensor loading times at login
  • Data Center Expert client launcher does not reopen...
  • DCE 7.9.3 to 8.0 server update progress in the web...
  • Changing the protocol used to monitor APC SNMP dev...
  • Change the IP address of a discovered device
  • APC Worldwide Customer Support
  • Unplugged sensors in DCE 7.4.3
  • NetBotz 750 discovery error
  • Say hello to EcoStruxure IT Expert!
  • How to increase RAM (memory) or CPU (processors) o...
  • Devices disappear after upgrading DCE to version 7...
  • How to add a private network (second network adapt...
  • Hi! Hello! Welcome to the EcoStruxure IT Help Cent...
  • Updated firmware available for APC Rack PDU 2G (AP...
EcoStruxure IT Support
Request Support
Back to DCE FAQ
  • Mark as Read
EcoStruxureIT
‎2022-12-07 02:08 AM
This issue was addressed in DCE 8.0.
EcoStruxure IT Data Center Expert 8.0 release notes
Changing some system settings or using the File > Change Server option in the Data Center Expert client causes DCE to restart. In DCE 7.7.1 and newer, the client launcher does not reopen after DCE restarts to allow you to log in again.
In DCE 7.9.3, the desktop shortcut created by the installer includes the -h parameter in the Target path to restore this functionality.
The executable in the installation directory does not include this parameter. If you want to create a shortcut from the executable in the installation directory, you must add the -h parameter to the Target path:
  1. Go to the dcexpert folder in the DCE installation directory.
    Example: C:\Program Files\StruxureWare Data Center Expert 7.9.3\dcexpert.
  2. Right click and select Create shortcut.
  3. Right click the shortcut, select Properties, and then select the Shortcut tab.
  4. Add -h to the end of the Target path after the end quotation.
  5. Click Apply.
