Uniflair DDF identification guide for Data Center Expert
DCE FAQ
  • EcoStruxure IT Help Center
  • DCE FAQ
  • Uniflair DDF identification guide for Data Center Expert
  • Mark as Read
  • What happens if my DCE subscription license expire...
  • Is a disaster recovery solution available for Data...
  • Data Center Expert REST API
  • APC Worldwide Customer Support
  • Data Center Expert sensor loading times at login
  • Data Center Expert client launcher does not reopen...
  • DCE 7.9.3 to 8.0 server update progress in the web...
  • Changing the protocol used to monitor APC SNMP dev...
  • Change the IP address of a discovered device
  • Hi! Hello! Welcome to the EcoStruxure IT Help Cent...
  • Say hello to EcoStruxure IT Expert!
  • Where can I download the Data Center Expert firmwa...
  • Unplugged sensors in DCE 7.4.3
  • Uniflair DDF identification guide for Data Center ...
  • Troubleshooting DCE backups
  • NetBotz 750 discovery error
  • Launch to Device does not work for NMC 1 devices o...
  • How to verify the checksum for the DCE update file
  • How to verify device support for DCE
  • How to reset the DCE Administrator password for th...
  • How to request a DDF
  • How to increase RAM (memory) or CPU (processors) o...
  • How to create a device walk file for Data Center E...
  • How to create a Windows share
  • How to add a private network (second network adapt...
  • Devices disappear after upgrading DCE to version 7...
  • Carel pCOWeb cards
EcoStruxure IT Support
Request Support
Back to DCE FAQ
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:15 AM
Last Updated: Nicholas.StPierre Cadet ‎2025-05-21 08:05 AM
This table will help you accurately identify the appropriate DDF for any Uniflair model.
Only one Carel pCOWeb SNMP DDF can be installed per DCE server regardless of vendor.
See Carel pCOWeb cards for more information.
NOTE: An asterisk (*) in the Device Family/SKU name indicates a wildcard value, for example, TRAF1221A1 and TRAC4042A1 would both fall under "TR******A (last letter is A).
NOTE: pCO5 and pCO5+ are different controllers.
Modbus
File Name Device Family/SKU Controller/Interface
uniflair_am_le_amico_leonardo_ug40mp40_Modbus_CCU
pCO1/UG40
Uniflair LE: TDCR, TUCR, TDCV, TUCV, IDAV, TDAR, TDDR, TDDV, TDER, TDTR,
TDTV, TDWR, TUAR, TUDR, TUDV, TUER, TUTR, TUTV, TUWR, TDAV, TDEV, TDWV, TUAV, TUEV, TUWV
Uniflair AM: SDA, SDC, SDW, SUA, SUC, SUW
uniflair_am_uniflair_le_amico_leonardo_ug50_TCPIP_Modbus_CCU
pCO5+/UG50
Uniflair LE: HDCV, HDCV5000D, HDCV5000L
uniflair_aquacentr_TCPIP_Modbus_chiller_imperial (imperial units only)
BCE*, BCW*
NOTE: pCO controller determines the correct DDF to use. Controller MUST match
pCO5+/UG50
uniflair_aquascrew_TCPIP_Modbus_chiller
BRE*
pCO5+/UG50
uniflair_aquascroll_TCPIP_Modbus_chiller
ERAC, ERAH, ERAF, ERCC, ERCH, ERCF
ISAC, ISAH, ISAF, ISCC, ISCH, ISCF
NOTE: Aquascroll Firmware
pCO5+/UG50
uniflair_aranew_TCPIP_Modbus_chiller ARAC, ARAH, ARAF pCO1/MP20II
uniflair_bce_TCPIP_Modbus_chiller
BCE*
pCO5/UG50
uniflair_bcwc_TCPIP_Modbus_chiller
BCW*
pCO3/UG50
uniflair_bra_TCPIP_Modbus_chiller BRA* pCO1/MP20II
uniflair_bref_TCPIP_Modbus_chiller
BRE*
NOTE: pCO controller determines the correct DDF to use. Controller MUST match.
pCO1/MP20II
uniflair_brwc_TCPIP_Modbus_chiller BRR*, BRW* pCO1/MP20II
uniflair_era_TCPIP_Modbus_chiller
NOTE: pCO controller and firmware determine the correct DDF to use. They MUST match.
NOTE: Does NOT use Aquascroll Firmware
pCO1/MP20II
uniflair_isa_TCPIP_Modbus_chiller
pCO1/MP20II
uniflair_lra_TCPIP_Modbus_chiller LRAC, LRAH pCOXS/-
uniflair_sp_uniflair_wm_uniflair_mb_telnew_TCPIP_Modbus_CCU
UCA* , UCF*, UWA*, UWF*,WDA*, WDF*, WMA*, WMF*,XDA* , XDF*, (ADD*/ XDD* displacement units), XMA*, XMF*
pCO1/UG40
uniflair_tra_TCPIP_Modbus_chiller
NOTE: TRA 1.x Firmware
pCO5+/UG50
SNMP
NOTE: Any file name with a leading asterisk (*) is included with a DCE installation.
NOTE: File names that are bold are considered pCOWeb SNMP DDFs as mentioned at the top of this article.
*apc_acrd2g ACRC60xx, ACRD60x Schneider C3P (R2)/Touch (4.3")
apc_air_economizer
IAEC25, IAEC50
Schneider J5-18DIN/Touch (7")
*apcacirg2 ACRD10x, ACRD20x Schneider C3P (mR1)/PowerView
*apcacsc ACSC10x Schneider C3P (mR1)/PowerView
*apcraru ACF40x Schneider ARU (mR1)/PowerView
*schneider_acrc301s ACRC30xx Schneider J5-13DIN/Touch (4.3")
*schneiderelectric_ledxg2 LD*V* / IX*V* / I**V* Schneider J5-18DIN/Touch (7")
schneiderelectric_tsatra TSA*, TR******A1 (last characters are A1) pCO5+/Touch (7")
uniflair_am_uniflair_le_amico_leonardo_ug40mp40_SNMP_CCU
pCO1/UG40
uniflair_am_uniflair_le_amico_leonardo_ug50mp50_SNMP_CCU
pCO5+/UG50
uniflair_aquacentr_SNMP_chiller_imperial (imperial units only)
BCE*, BCW*
pCO5+/UG50
uniflair_aquascrew_SNMP_chiller
BRE*
pCO5+/UG50
uniflair_aquascroll_SNMP_chiller
pCO5+/UG50
uniflair_aranew_SNMP_chiller ARAC, ARAH, ARAF pCO1/MP20II
uniflair_bce_SNMP_chiller (metric units only)
BCE*
pCO5/UG50
uniflair_bra_SNMP_chiller BRA* pCO1/MP20II
uniflair_bref_SNMP_chiller
BRE*
pCO1/MP20II
uniflair_brwc_SNMP_chiller BRR*, BRW* pCO1/MP20II
uniflair_era_SNMP_chiller
pCO1/MP20II
uniflair_isa_SNMP_chiller
pCO1/MP20II
*uniflair_le_ddf
T*C* (third letter "C")
HDCV*
T*AG, T*DG, T*WG, T*TG, T*EG, (last letter G)
pCO5+/Touch (7")
Uniflair_LEL LDCV* pCO5+/Touch (7")
uniflair_lra_SNMP_chiller LRAC, LRAH pCOXS/-
uniflair_sp_uniflair_wm_uniflair_mb_telnew_SNMP_CCU UCA* , UCF*, UWA*, UWF*,WDA*, WDF*, WMA*, WMF*,XDA* , XDF*, (ADD*/ XDD* displacement units), XMA*, XMF* pCO1/UG40
uniflair_trac_SNMP_chiller
pCO5+/UG50
100% helpful (1/1)
