  • Mark all as New
  • Mark all as Read
  • Float this item to the top
  • Invite a Friend
  • Threaded format
  • Linear Format
  • Sort by Topic Start Date
The message you are trying to access is permanently deleted.
wiser-logo
Conversation by Products
Explore our products forum and get answers to your questions:
Temperature control
Temperature control
Safety
Safety
Security
Security
Apps
Apps
Gateways
Gateways
Lighting
Lighting
Energy management
Energy management
Shutter and blind
Shutter and blind
Voice control
Voice control
Top Labels
Top Labels
  • Alphabetical
  • Temperature Control 86
  • Apps 68
  • About Wiser 59
  • Energy management 29
  • Gateways 19
  • Gateways and Hubs 18
  • Bugs 15
  • Lighting 14
  • Connectivity Devices 12
  • Shutter and Blind 12
  • Knowledge questions 12
  • Mobile Applications 11
  • Safety 11
  • Energy devices 11
  • Voice Control 8
  • Security 8
  • Announcements and Release Notes 7
  • Usability issues 7
  • OTHERS 7
  • User Testimonials 6
  • Ideas of improvements 4
  • Others & accessories 1
  • Did you know 1
  • Communicating Actuators and Energy Valves 1
  • Thermostats 1
  • Visual feedback 1
  • Previous
  • 1 of 2
  • Next
David_SE
Captain David_SE Captain
140
Alfred_SE
24
Maude.wiser.
22
BrianT58
Lieutenant BrianT58
18
Thumbnail of Wiser
Wiser
8
Thumbnail of Wiser for KNX : logic controller
6
Thumbnail of PowerLogic™ PowerTag
2
  • All
  • Solved
  • Unsolved
  • Unanswered
Informational
David_SE
/html/rank_icons/Captain.png David_SE /html/rank_icons/SE-Employee.png
Wiser Home app new version - v7.3.0 & Wiser Home Hub 2nd Gen new FW ve...
Dear Wiser user, A new Wiser Home app version v7.3.0 and a new Wiser Home Hub 2nd Gen FW version 4.42.23 will be deployed that week. In addition to bug fixes and enhancements, this release co...
Schneider Electric Wiser icon_circle Schneider Electric Wiser Forum
526 1 1
Latest Reply: Fozzie1960
Alfred_SE
Alfred_SE /html/rank_icons/Retired-User.png
Welcome to the Schneider Electric Wiser Community!
Dear Wiser user, Interact with other #Wiser users while staying up to date on the newest news, features, and customer stories. Have a #Wiser Life! A whole new #Wiser environment for you to get to...
4026 9 3
Latest Reply: StewartT
Fred38
Fred38 /html/rank_icons/SE-Employee.png
Unable to connect the Gateway from a remote 4G/5G connection
Hi,I'm a new user to the system.I just installed a Wiser Gen 2 with few Powertag R9M60.All seems to be ok when I am on my home network (Wifi). I can access the App, see the gateway, the tags, etc...How...
53 0 3
Latest Reply: David_SE
MalcolmSu
MalcolmSu
Device firmware
Across all the devices I have connected to my Wiser hub, in each category, all the devices are on the same level of firmware, except for one. One Room Thermostat is several versions behind all the oth...
16 0 1
prepare3envelopes
/html/rank_icons/Ensign.png prepare3envelopes
Factory Reset Wiser Home Energy Monitor?
How do I factory reset the Home Energy Monitor (green Sense hardware) so I can give it to someone else so they link it to their account? When we had the Wiser app there was a factory reset option but I...
18 0 0
2025-11-04
diogosilva_2002
diogosilva_2002
Wiser Alexa
Hi, I have a Wiser in my office at work and we have an Alexa. The Wiser controls a curtain, so it can be operated by voice command using Alexa. But a few weeks ago, it stopped working. I say, ‘Alexa,...
33 0 1
Suikam
/html/rank_icons/Crewman.png Suikam
Wiser Energy Monitor to Schneider Home App
On July 31st I was forced to upgrade my Wiser Energy App to the new Schneider Home app. Since then I lost all of the monitor readings and old data. I opened a support case two weeks ago and so far no...
626 3 5
CollapsedOrange
CollapsedOrange
Matter issues on 2nd gen Hub
Hey, so I'm a bit stuck trying to set up the Matter stuff. When I first upgraded to the 2nd gen hub, I did a quick test to see if it worked, and it did. The issue is I only added one rad at the time, s...
101 0 1
mickiete
mickiete
Temperature Display Offset
Is there a way to offset the temperature reading display on the app by a room stat as the readings I am getting from the sensors are about 2 deg lower than the actual rooms after checking with other di...
21 0 0
2025-11-02
OKC171166
/html/rank_icons/Crewman.png OKC171166
Wiser Gen 2 - CH Cycling every 10 minutes
We have a Worcester Bosch 18 RI boiler (non-open therm) connected to a Wiser Gen 2 thermostat. We noticed that the thermostat would ask the boiler to come on and go off every 10 minutes. We spoke with ...
669 0 10
Latest Reply: OKC171166
DanIOM
/html/rank_icons/Crewman.png DanIOM
No longer able to add a new wiser device
I am no longer able to add a new wiser device (neither plug nor TRV) into the Wiser app. My existing home Hub setup with multiple TRV's continues to work, I can control the existing devices within ...
466 0 10
Latest Reply: JPJersey
LondonWiserUser
/html/rank_icons/Crewman.png LondonWiserUser
Using smart plug as range extender - some questions
Hi all, I've been using the Wiser smart heating system in my home for about a month now. It's a three-storey house with the Heat Hub R located next to a combi boiler in the middle of the top floor. W...
8988 0 10
MalcolmSu
MalcolmSu
Upgrade to 2nd Generation Hub
I'm about to commence my upgrade to the 2nd Generation hub. I've watched this video on the Drayton Controls YouTube channel. It states I have to delete the room and radiator thermostats from the existi...
142 0 2
  • « Previous
    • 1
    • 2
    • 3
    • 27
  • Next »
