Posted: 2025-11-03 08:57 AM
I'm a new user to the system.
I just installed a Wiser Gen 2 with few Powertag R9M60.
All seems to be ok when I am on my home network (Wifi). I can access the App, see the gateway, the tags, etc...
However, when connecting from remote, when I launch the app, the connection to the gateway seems not working, I have a error message as if the gateway was not installed.
Can you please help me there ?
Thanks.
Posted: 2025-11-12 02:57 AM
Hi David,
Very weird, as indeed I did reset the GW 04-49-DA to disconnect it from my account to be able to connect the other one.
So yes I'm using the GW 05-4C-FB on my account, but FYI, I'm intending to create a new account to use the other one for another location.
=> Now as a side note, as many other users asked already, the possibility to manage 2 or multiple GW from one account is long time overdue and becomes critical now. I'm sure it is on the roadmap but would really need to be accelerated ;-). Thanks.
Posted: 2025-11-04 06:35 AM
Hi @Fred38 ,
Sorry to read that you don't have remote access to your Wiser Home system, is it possible for you to share only the MAC address of the hub here so then i can have a look. Depending on "my" result, i will ask you to contact our local customer support.
BR
David
Posted: 2025-11-06 05:39 AM
Hi David,
Sure happy to share. MAC address finishing by 05-4C-FB. Firmware is 4.42.23.
Thanks.
Posted: 2025-11-06 03:13 PM
Hi @Fred38 ,
I saw that you have 2 hubs connected to your account and that configuration is not compatible, probably due to the fact that you use the same account email.
Please can you confirm that you don't use the hub with MAC 04-49-DA?
Then, i will try to solve the issue with technical team.
BR
David
Hi David,
Posted: 2025-11-14 01:01 AM
Hi David,
Thanks for marking my answer as Solution, but at this stage, it is still not working. Access to my wiser Account from 4G still brings me an error: not finding th GW.
Have your team been able to do somehting ? Do I have to do something specific on my side ?
Many Thanks.
