  • Mark all as New
  • Mark all as Read
  • Float this item to the top
  • Invite a Friend
  • Threaded format
  • Linear Format
  • Sort by Topic Start Date
The message you are trying to access is permanently deleted.
wiser-logo
Conversation by Products
Explore our products forum and get answers to your questions:
Temperature control
Temperature control
Safety
Safety
Security
Security
Apps
Apps
Gateways
Gateways
Lighting
Lighting
Energy management
Energy management
Shutter and blind
Shutter and blind
Voice control
Voice control
Top Labels
Top Labels
  • Alphabetical
  • Temperature Control 84
  • Apps 68
  • About Wiser 59
  • Energy management 29
  • Gateways 19
  • Gateways and Hubs 17
  • Lighting 14
  • Connectivity Devices 12
  • Shutter and Blind 12
  • Bugs 11
  • Knowledge questions 11
  • Safety 11
  • Mobile Applications 10
  • Energy devices 10
  • Voice Control 8
  • Security 8
  • Announcements and Release Notes 7
  • Usability issues 7
  • OTHERS 7
  • User Testimonials 6
  • Ideas of improvements 4
  • Others & accessories 1
  • Did you know 1
  • Communicating Actuators and Energy Valves 1
  • Thermostats 1
  • Visual feedback 1
  • Previous
  • 1 of 2
  • Next
David_SE
Captain David_SE Captain
139
Alfred_SE
24
Maude.wiser.
22
BrianT58
Lieutenant BrianT58
18
Thumbnail of Wiser
Wiser
8
Thumbnail of Wiser for KNX : logic controller
6
Thumbnail of PowerLogic™ PowerTag
2
  • All
  • Solved
  • Unsolved
  • Unanswered
Informational
David_SE
/html/rank_icons/Captain.png David_SE /html/rank_icons/SE-Employee.png
Wiser Home app new version - v7.3.0 & Wiser Home Hub 2nd Gen new FW ve...
Dear Wiser user, A new Wiser Home app version v7.3.0 and a new Wiser Home Hub 2nd Gen FW version 4.42.23 will be deployed that week. In addition to bug fixes and enhancements, this release co...
Schneider Electric Wiser icon_circle Schneider Electric Wiser Forum
367 1 1
Latest Reply: Fozzie1960
Alfred_SE
Alfred_SE /html/rank_icons/Retired-User.png
Welcome to the Schneider Electric Wiser Community!
Dear Wiser user, Interact with other #Wiser users while staying up to date on the newest news, features, and customer stories. Have a #Wiser Life! A whole new #Wiser environment for you to get to...
3730 9 3
Latest Reply: StewartT
MalcolmSu
MalcolmSu
Upgrade to 2nd Generation Hub
I'm about to commence my upgrade to the 2nd Generation hub. I've watched this video on the Drayton Controls YouTube channel. It states I have to delete the room and radiator thermostats from the existi...
12 0 1
Latest Reply: Dyhia
DanIOM
/html/rank_icons/Crewman.png DanIOM
No longer able to add a new wiser device
I am no longer able to add a new wiser device (neither plug nor TRV) into the Wiser app. My existing home Hub setup with multiple TRV's continues to work, I can control the existing devices within ...
256 0 7
Latest Reply: JoC
OKC171166
OKC171166
Wiser Gen 2 - CH Cycling every 10 minutes
We have a Worcester Bosch 18 RI boiler (non-open therm) connected to a Wiser Gen 2 thermostat. We noticed that the thermostat would ask the boiler to come on and go off every 10 minutes. We spoke with ...
399 0 6
Latest Reply: KTilbury
LondonWiserUser
/html/rank_icons/Crewman.png LondonWiserUser
Using smart plug as range extender - some questions
Hi all, I've been using the Wiser smart heating system in my home for about a month now. It's a three-storey house with the Heat Hub R located next to a combi boiler in the middle of the top floor. W...
8532 0 9
Latest Reply: dwbuk
Verelec
Verelec
Wiser2 (5200WHC2) failure after firmware (1.32.4) update with Piced 4....
Hi all, during a routine service call at a client I was kindly sked to perform a small change in the Wiser2 widgets. That is simple in itself except that the firmware update bricked the Wiser2 during t...
187 0 3
Latest Reply: David_SE
BartinFrance
BartinFrance
Wiser home app Login
I use the Wiser Home app on an iPhone 12 iOS 18.6.2. I have two hubs, so I have to log in and out with my email address and password to switch between hubs. This information is stored in my smartphone'...
111 0 2
Latest Reply: BartinFrance
Suikam
/html/rank_icons/Crewman.png Suikam
Wiser Energy Monitor to Schneider Home App
On July 31st I was forced to upgrade my Wiser Energy App to the new Schneider Home app. Since then I lost all of the monitor readings and old data. I opened a support case two weeks ago and so far no...
454 3 3
Latest Reply: Lcornejo80
Verelec
Verelec
Failed CBus Wiser2 Firmware
Hi all, Wiser2 5200WHC2, Toolkit 1.19, Piced 4.14.2 firmware 1.32.4 during a routine service call at a client I was kindly sked to perform a small change in the Wiser2 widgets. That is simple in itse...
110 0 1
Martinez838
Martinez838
Wiser dimmer flashing LED Issue
Having issues with the wiser connected dimmer 41EPBDWCLMZ TV2522 / PDL354PBDMBTZ I have tried 3 separate dimmers to which all are having the same issue Issue: The white LED flashes 5 times, pause fo...
203 0 3
cndesu
cndesu
On-boarding issues with Square D wifi switch
Hi, I have square D wifi smart switch. It is matter compatible. I used Schneider home app and boarded the switches. Issue is, could not connect to SmartThings or Google home. Tried to use wiser app, bu...
53 0 0
2025-10-20
sberry
sberry
TRV plunger not retracting enough after battery change
When installed from new, my radiator TRV worked fine. However, when it came to changing the batteries, the TRV wouldn't open enough to allow any heat into the radiator. I replaced the batteries and c...
45 0 0
2025-10-18
  • « Previous
    • 1
    • 2
    • 3
    • 26
  • Next »
