Continue
  • My Subscriptions
  • Events
TRV plunger not retracting enough after battery change
  • TRV plunger not retracting enough after battery change
David_SE
David_SE Mentor
214
Alfred_SE
Alfred_SE Leader
24
Maude.wiser.
Maude.wiser. Contributor
22
sberry
sberry
Explorer
Posted: ‎2025-10-18 07:43 AM
3
1831
When installed from new, my radiator TRV worked fine.  However, when it came to changing the batteries, the TRV wouldn't open enough to allow any heat into the radiator.  I replaced the batteries and calibrated the TRV, but I noticed that, when inserting the new batteries, the plunger goes all the way into the body of Wiser head, however when it asks for heat, the plunger only retracts 1mm or so.  To get any heat into the radiator I have to back off the head by 3/4 to 1 turn.
More and more of my TRVs are exhibiting this behaviour.
Any ideas as to why this is happening and how I can resolve it?
  • Temperature Control
David_SE
David_SE Mentor
Mentor
Posted: ‎2026-01-26 05:27 AM
Post closed as no reply for 2 months. Please reopen a new post if needed.
Thanks.
David
David_SE
David_SE Mentor
Mentor
Posted: ‎2025-11-27 03:17 AM
hi @sberry ,
Thanks for your post, you need to redo the calibration without removing the batteries.
Please see the video below for process.
Thanks.
BR
David
iTRV Calibration after pairing
Steven4
Steven4
Explorer
Posted: ‎2025-11-27 09:46 AM
I am experiencing this same problem with one of my TRVs. According to the app the TRV will be calling for heat but the plunger doesn’t retract enough to allow flow through the radiator.  If I remove the head the flow is fine so the pin is ok.  I have tried resetting the TRV and recalibrating (as per David’s advice) several times. It has been fine for the first year. Batteries checked and changed. Did you (sherry) find a solution?
David_SE
David_SE Mentor
Mentor
Thanks.
David
