  • Mark all as New
  • Mark all as Read
  • Float this item to the top
  • Invite a Friend
  • Threaded format
  • Linear Format
  • Sort by Topic Start Date
The message you are trying to access is permanently deleted.
wiser-logo
Conversation by Products
Explore our products forum and get answers to your questions:
Temperature control
Temperature control
Safety
Safety
Security
Security
Apps
Apps
Gateways
Gateways
Lighting
Lighting
Energy management
Energy management
Shutter and blind
Shutter and blind
Voice control
Voice control
Top Labels
Top Labels
  • Alphabetical
  • Temperature Control 86
  • Apps 68
  • About Wiser 59
  • Energy management 29
  • Gateways and Hubs 21
  • Gateways 19
  • Bugs 16
  • Lighting 14
  • Connectivity Devices 13
  • Shutter and Blind 12
  • Knowledge questions 12
  • Mobile Applications 11
  • Safety 11
  • Energy devices 11
  • Usability issues 9
  • Voice Control 8
  • Security 8
  • Announcements and Release Notes 7
  • OTHERS 7
  • User Testimonials 6
  • Ideas of improvements 5
  • Others & accessories 1
  • Did you know 1
  • Communicating Actuators and Energy Valves 1
  • Thermostats 1
  • Visual feedback 1
  • Previous
  • 1 of 2
  • Next
David_SE
Captain David_SE Captain
140
Alfred_SE
24
Maude.wiser.
22
Thumbnail of Wiser
Wiser
8
Thumbnail of Wiser for KNX : logic controller
6
Thumbnail of PowerLogic™ PowerTag
2
  • All
  • Solved
  • Unsolved
  • Unanswered
Informational
David_SE
/html/rank_icons/Captain.png David_SE /html/rank_icons/SE-Employee.png
Wiser Home app new version - v7.3.0 & Wiser Home Hub 2nd Gen new FW ve...
Dear Wiser user, A new Wiser Home app version v7.3.0 and a new Wiser Home Hub 2nd Gen FW version 4.42.23 will be deployed that week. In addition to bug fixes and enhancements, this release co...
Schneider Electric Wiser icon_circle Schneider Electric Wiser Forum
671 1 1
Latest Reply: Fozzie1960
Alfred_SE
Alfred_SE /html/rank_icons/Retired-User.png
Welcome to the Schneider Electric Wiser Community!
Dear Wiser user, Interact with other #Wiser users while staying up to date on the newest news, features, and customer stories. Have a #Wiser Life! A whole new #Wiser environment for you to get to...
4277 9 3
Latest Reply: StewartT
Suikam
/html/rank_icons/Crewman.png Suikam
Wiser Energy Monitor to Schneider Home App
On July 31st I was forced to upgrade my Wiser Energy App to the new Schneider Home app. Since then I lost all of the monitor readings and old data. I opened a support case two weeks ago and so far no...
723 3 6
Latest Reply: Tyea
DanIOM
/html/rank_icons/Crewman.png DanIOM
No longer able to add a new wiser device
I am no longer able to add a new wiser device (neither plug nor TRV) into the Wiser app. My existing home Hub setup with multiple TRV's continues to work, I can control the existing devices within ...
760 0 13
Latest Reply: CS44
ZULU1875
ZULU1875
Wiser Automation smart plug.
Hello, 👋🏼, ok I’m going to make myself look silly not for the first time but I'm pulling my hair out. Can’t get any of my 3 smart plugs to operate in Automation. ( they are all connected to lamps ) I...
74 0 3
Latest Reply: BrianT58
Fred38
/html/rank_icons/Crewman.png Fred38 /html/rank_icons/SE-Employee.png
Unable to connect the Gateway from a remote 4G/5G connection
Hi,I'm a new user to the system.I just installed a Wiser Gen 2 with few Powertag R9M60.All seems to be ok when I am on my home network (Wifi). I can access the App, see the gateway, the tags, etc...How...
191 0 5
Latest Reply: Fred38
JR5
JR5
Wiser hub v2 connection error
I have followed hub wifi tips here, have latest iPhone and wiser firmware have fixed 2.4ghz wifi channel, reserved ip address for the hub in my router but still have connection errors every few days. ...
81 0 2
Latest Reply: SYM
chourmovs
/html/rank_icons/Crewman.png chourmovs
wiser CCT501801 soft brick ??
Hi, When I came back from vacation, my Wiser Hub Gen 2 (CCT501801) was showing a solid red LED.I rebooted it, and now every time it starts, it connects to my router (receives IP 192.168.1.125 and shows...
113 1 2
Latest Reply: David_SE
Niall1
Niall1
Wiser hub 2 disconnected from internet and lost all programming except...
My wiser hub 2 was disconnected from the internet and flashing red. When I went in to the app to reconnect it I had lost all the programming except for one radiator micro module and one thermostat. I h...
67 0 1
Olympe
Olympe
Firmware Passerelle Génération 2
Bonjour, j'ai 2 passerelle génération 2 (dans 2 endroits) mais l'une est restée à la version 4.18.36 alors que l'autre est en 4.42.23. les 2 sont connectées à internet (et au cloud wiser). le soucis c...
61 0 1
Verelec
Verelec
Wiser2 (5200WHC2) failure after firmware (1.32.4) update with Piced 4....
Hi all, during a routine service call at a client I was kindly sked to perform a small change in the Wiser2 widgets. That is simple in itself except that the firmware update bricked the Wiser2 during t...
478 0 4
Latest Reply: Goodbrat22
Pyrotech
Pyrotech
Noisy smart thermostat heads
I have installed a wiser kit 1 to our 3 storey town house due to the temperature difference between floors. The system works well in conjunction with wet underfloor heating on the ground floor. However...
24 0 0
2025-11-12
MalcolmSu
/html/rank_icons/Crewman.png MalcolmSu
Device firmware
Across all the devices I have connected to my Wiser hub, in each category, all the devices are on the same level of firmware, except for one. One Room Thermostat is several versions behind all the oth...
136 0 2
Latest Reply: MalcolmSu
  • « Previous
    • 1
    • 2
    • 3
    • 28
  • Next »
