Wiser Automation smart plug.
  • Wiser Automation smart plug.
David_SE
Captain David_SE Captain
149
Alfred_SE
24
Maude.wiser.
22
ZULU1875
ZULU1875
Cadet
Posted: ‎2025-11-12 01:09 PM
214
Hello, 👋🏼,
ok I’m going to make myself look silly not for the first time but I'm pulling my hair out.
Can’t get any of my 3 smart plugs to operate in Automation. ( they are all connected to lamps )
I go…..
Automation, any conditions, add condition, device status ( I choose utility lamp ) On/Off I tap On and then set. I choose When, Add time etc etc. what am I doing wrong please??
If somebody sorts me out I’ll send a prayer your way tonight. Thank you.
  • Usability issues
BrianT58
Lieutenant BrianT58
Lieutenant
Posted: ‎2025-11-14 01:59 AM
  1. In the App go to automations, at the top you should have a choice of moments and schedules. Choose schedules.
  2. click the plus at the top right.
  3. Give the schedule a name.
  4. change the Type scrollbar to Appliances
  5. select the extender (smart plug) you wish to automate, it can be more than 1
  6. Click create (your new default schedule has been created)
  7. Click see my schedule.
  8. Adjust the times to suit your needs and then either copy that day to any other day, or all. Hopefully that should save you a call.
Regards Brian
(Hub 2, 15 TRV's, 2 rooms stats and 3 extenders)
David_SE
Captain
Posted: ‎2025-11-13 02:22 PM
Hi @ZULU1875 ,
Thanks for your post and sorry to read that you didn't succeed to add an automation with a smart plug.
With the shared information, it is difficult to help you, please can you contact our local customer support ?
Thanks.
BR
David
Customer support contacts
PS : if you are located in UK, our customer support can be contacted at support@schneider-electric.zendesk.com or alternatively call us on 0333 600 022 (option 2, then 2)
SYM
Crewman SYM
Crewman
Posted: ‎2025-11-13 09:43 PM
My only observation would be check that you have enabled the automation in the Automation section by sliding the on/off slider to the on position.
BrianT58
Lieutenant BrianT58
Lieutenant
Regards Brian
