Where is the registration code to connect the Gateway to EcoStruxure IT?
Gateway FAQ
Answers to common questions about the EcoStruxure IT Gateway
  • EcoStruxure IT Help Center
  • Gateway
  • Gateway FAQ
  • Where is the registration code to connect the Gateway to EcoStruxure IT?
  • Mark as Read
  • How to identify APC Network Management Card 1 (NMC...
  • Where is the registration code to connect the Gate...
  • Where can I find the Gateway discovery log?
  • Uniflair device discovery for EcoStruxure IT Gatew...
  • Ripple20 vulnerabilities in the Treck TCP/IP stack
  • Modbus gateways
  • How to update the Gateway device library
  • How to reset the Gateway admin password in Gateway...
  • How to request device support for EcoStruxure IT G...
  • How to find the EcoStruxure IT Gateway serial numb...
  • How to discover a Uniflair cooling device - Gatewa...
  • How to discover NetBotz appliances in Gateway
  • How to connect to EcoStruxure IT using Data Center...
  • How to change device file transfer settings in the...
  • How can I see if my device is currently supported?
  • Gateway support for multiple network adapters
  • Gateway auto-update in IT Expert
  • EcoStruxure IT Gateway date and time settings
  • Do I need a dedicated server for EcoStruxure IT Ga...
  • Connecting a Smart-UPS to the Gateway with serial ...
  • Can the Gateway discover SmartConnect UPSs?
  • Can I change the default subnet for the Gateway ap...
  • Can EcoStruxure IT Gateway discover devices on the...
  • Modbus gateways
EcoStruxure IT Support
Request Support
Back to Gateway FAQ
  • Mark as Read
Picard EcoStruxureIT
‎2020-02-25 12:15 PM
The registration code is used to connect the Gateway to EcoStruxure IT. It appears on the Register Gateway page in the Gateway setup wizard.
Once you exit the setup wizard, the code appears on the Cloud connectivity page if the Gateway is not connected.
GW18_configure_connectivity_360006171818.PNGGW18_configure_connectivity_360006171818.PNG
When the Gateway is connected, the code is not displayed.
GW18_register_Gateway_complete_360006171818.pngGW18_register_Gateway_complete_360006171818.png
If your Gateway can't connect to the cloud, please contact EcoStruxure IT Support for assistance.
Note: This code registers the Gateway with EcoStruxure IT only. It is not the same as the recovery code you can use to authenticate with EcoStruxure IT.
