How to change device file transfer settings in the Gateway from FTP to SCP
Gateway FAQ
Answers to common questions about the EcoStruxure IT Gateway
  • EcoStruxure IT Help Center
  • Gateway
  • Gateway FAQ
  • How to change device file transfer settings in the Gateway from FTP to SCP
  • Mark as Read
  • How to identify APC Network Management Card 1 (NMC...
  • Where is the registration code to connect the Gate...
  • Where can I find the Gateway discovery log?
  • Uniflair device discovery for EcoStruxure IT Gatew...
  • Ripple20 vulnerabilities in the Treck TCP/IP stack
  • Modbus gateways
  • How to update the Gateway device library
  • How to reset the Gateway admin password in Gateway...
  • How to request device support for EcoStruxure IT G...
  • How to find the EcoStruxure IT Gateway serial numb...
  • How to discover a Uniflair cooling device - Gatewa...
  • How to discover NetBotz appliances in Gateway
  • How to connect to EcoStruxure IT using Data Center...
  • How to change device file transfer settings in the...
  • How can I see if my device is currently supported?
  • Gateway support for multiple network adapters
  • Gateway auto-update in IT Expert
  • EcoStruxure IT Gateway date and time settings
  • Do I need a dedicated server for EcoStruxure IT Ga...
  • Connecting a Smart-UPS to the Gateway with serial ...
  • Can the Gateway discover SmartConnect UPSs?
  • Can I change the default subnet for the Gateway ap...
  • Can EcoStruxure IT Gateway discover devices on the...
  • Modbus gateways
EcoStruxure IT Support
Request Support
Back to Gateway FAQ
  • Mark as Read
Picard EcoStruxureIT
‎2020-11-23 01:46 AM
Last Updated: Sisko JLehr Sisko ‎2023-09-09 07:42 AM
SCP is a secure alternative to FTP for event.txt, device configuration, and firmware update.  It is strongly recommended that you use SCP and disable FTP on your APC NMC-based devices (NMC2 and NMC3).
The EcoStruxure IT Gateway does not support SCP on NMC1 devices.
How to identify APC Network Management Card 1 (NMC1) devices
SCP is supported in EcoStruxure IT Gateway 1.9.0 and newer.
The FTP or SCP credentials on the device must match the device transfer settings on the Gateway Settings > Device credentials page.
IT Expert Administrator users can change these settings on APC SNMP devices that support config.ini.
See Single device configuration and Device configuration.
Otherwise, refer to your device's documentation for instructions on how to set FTP or SCP credentials.
IMPORTANT: After you update the device configuration settings in the Gateway, you must rediscover the devices that you modified to use SCP credentials.
For instructions, see Configure Gateway device file transfer settings
Also see How to enable SCP on APC NMC devices in IT Expert
